Engine Running Hotter with Plenum??
Old Aug 23, 2004 | 10:50 PM
maserom's Avatar
maserom
Default Engine Running Hotter with Plenum??
Just installed the V4 this weekend. I could very well be wrong, but the motor seems to be getting much hotter since installing the plenum? 2 reasons, when opening up the hood after driving, it seems much hotter inside. 2nd, the electric fan appears to be coming on sooner than before. The fan now comes on after 10 minutes of normal driving.
How far off am i in assuming this? If it is true, could there be a different thormostat that i could install to off set this?
Old Aug 23, 2004 | 11:16 PM
Zmego1985's Avatar
Zmego1985
Default Re: Engine Running Hotter with Plenum??
Its your headers the heat shields are removed so the heat rises now. Its fine dont worry about it mine is the same way its not the plenum.
Old Aug 24, 2004 | 02:05 AM
teh215's Avatar
teh215
Default Re: Re: Engine Running Hotter with Plenum??
Huh? What do the heat shields on the stock headers have to do with installing a plenum?
Old Aug 24, 2004 | 07:44 AM
arodbrs's Avatar
arodbrs
Default who's right and who's confused
im going to install mine today, now im in fear for my motor overheating, or something else, please state the facts.
worried z lover???????????????
Old Aug 24, 2004 | 07:45 AM
arodbrs's Avatar
arodbrs
was ur install difficult, ur in la. l live in the valley maybe we can talk and u can help me
thnx, thnx
Old Aug 24, 2004 | 08:11 AM
maserom's Avatar
maserom
The install was very easy, just be very careful, not to overtighten the bolts and don't drop any.
I've had headers on for quite some time now, and the fan comin on was never an issue until the plenum was installed.
Can i instal a different thormostate??
Old Aug 24, 2004 | 08:30 AM
THX723's Avatar
THX723
You might want to check the coolant by-pass block and see if it flows freely.
Old Aug 24, 2004 | 09:06 AM
Zmego1985's Avatar
Zmego1985
You dont have heat shields with headers on, with the stock manifolds you do. I wasnt talking about the stock setup i was about the after market headers being on his car causing it.
Thanks Glen
Old Aug 24, 2004 | 11:00 AM
ares's Avatar
ares
Veteran
yeah, Id be examing the coolant block. seems like a logical place to start. maybe it was malformed inside and is blocking flow.
Old Aug 24, 2004 | 11:31 AM
maserom's Avatar
maserom
How can i check to see without removing the Plenum?
Old Aug 24, 2004 | 12:14 PM
THX723's Avatar
THX723
Hmm ... interesting ... I've never even thought of that.
In that case, I would suggest bypassing that block completely by using a typical coupler that could be purchased at Home Depo. or other hardware plumbing stores. It is possible to disconnect the two hoses connected to the bypass block w.o. taking the plenum off. You'll need to disonnect the intake tube and a bit of elbow grease ought to do it. Run that setup and see if your cooling issue is resolved.
Good Luck.
Old Aug 24, 2004 | 12:45 PM
gspot35's Avatar
gspot35
It could also be the fact thay you added a PERFORMANCE MOD. How do we get more performance, added air and fuel mix. In your case it may just be more added air. We all know that more air creates a leaner combustion which creates more heat than a richer combustion. I'd chalk it up to your engine makes more power thus needing more cooling. You should lift the hood on a F/I car someday and you'll be thinking how does the plastic and rubber keep from melting in there.
Good Luck.
Old Aug 24, 2004 | 01:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the fan is triggered by coolant temp....so maybe the car is reaching operating temp sooner....not a bad thing at all IMHO
Old Aug 24, 2004 | 01:16 PM
ares's Avatar
ares
Veteran
I dont think the plenum is adding THAT much air to make a noticable difference. specially since no one else noticed.
furthermore, some pics have been posted of the internal casting on the plenum which would not make me doubt for a second that the coolant block might not have formed quite right.
Old Aug 25, 2004 | 09:48 AM
winw's Avatar
winw
That was my first thought until someone mentioned the headers not having heat shields. All of this could contribute. With FI, everyone with it would be wise to periodically inspect on those hoses and connections that will become brittle over time from the heat being generated in amounts for which they were not designed. Even in engines designed for FI, this is a maintenance issue.
Old Aug 25, 2004 | 03:05 PM
RA11325's Avatar
RA11325
just bypass the coolant block, you are in LA it will never get cold enough where you will need it.
Old Aug 25, 2004 | 07:45 PM
scubasteve's Avatar
scubasteve
When I replaced my V3 for a V4, I noticed that I had a lot of coolant residue around the coolant block fittings. I was also thinking about bypassing the stupid thing, but thought that it was made for a reason. Let us all know how the bypass thing goes. Anyone else here done this before?
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
