Bolt Broke outside Intake Plenum!! HELP
Old Sep 1, 2004 | 02:36 PM
maserom's Avatar
maserom
Default Bolt Broke outside Intake Plenum!! HELP
I have a broken bolt on the outside of the intake plenum that snaped off, one of the 10 bronze colored bolts. What is the best way to get it out? I was thinking of using a dremel and placing a screw in the middle and hopefully screwing it out.
Old Sep 1, 2004 | 02:50 PM
murrman100's Avatar
murrman100
Don't use the dremel. You might mess it up more.
You need a tap and die set. Its the best way.
Go to any hardware store and get one.
Old Sep 1, 2004 | 04:38 PM
maserom's Avatar
maserom
The bold is broken in half. The lower half is still in the intake. I was going to drill a hole in the center of the broken bolt and try to unscrew it that way. Would that work???
Old Sep 1, 2004 | 04:44 PM
xxlbeerZ's Avatar
xxlbeerZ
Just go buy a tap and die set!
Old Sep 1, 2004 | 05:15 PM
spdu4ia's Avatar
spdu4ia
yep... save yourself the grief
Old Sep 1, 2004 | 05:27 PM
maserom's Avatar
maserom
How can a tap and dye set get a broken bolt out of a plenum?? The bolt is broken in half. We are talking about the 10 bolts around the plenum.. Sorry for not understanding.
Here is a pic.
Old Sep 1, 2004 | 05:55 PM
dduck44's Avatar
dduck44
Go to Sears and look in the drill bot section, you'll see a countersunk spring-loaded drill bit it's used to set hinge plates on doors, the countersunk part mates w/the countersunk hinge plate you then press and the drill bit emerges and guarantees a perfectly centered hole-hard to explain. Anyway, using this device you could center it over the hole and press and drill into the broken bolt, then use an EZ out, also at Sears and back the threaded stud out.
Old Sep 1, 2004 | 06:04 PM
maserom's Avatar
maserom
Thank you so much!!
Old Sep 1, 2004 | 06:08 PM
JCat's Avatar
JCat
1. File or grind the remaining stud flat.
2. Center punch the center.
3. If you can, drill a hole in the middle of the remainding stud using a drill size matched to a tool called an EASY OUT. The EASY OUT is a special reverse threaded, tapered, and hardened tool. It grabs the remaining stud from inside the drilled hole and allows you to unscrew it.
A tap will clean and restore the threads in the hole once you remove the stud.
Old Sep 1, 2004 | 06:38 PM
ares's Avatar
ares
Veteran
yup, we know what your talking about; and this is what you need. its what it was made for.
Old Sep 2, 2004 | 02:02 AM
Duflacci's Avatar
Duflacci
get a set of easy outs from sears
Old Sep 2, 2004 | 08:13 AM
maserom's Avatar
maserom
i purchased the new easy out from Sears and a new drill set. Broken bolt = $115 in new stuff. Gotta love it.
Thanks everyone!!
Old Sep 2, 2004 | 10:31 AM
Duflacci's Avatar
Duflacci
Thanks everyone!!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
