Injen exhaust problem. ( PICS )
Old Oct 21, 2004 | 07:39 PM
maximumsportZ's Avatar
maximumsportZ
Default Injen exhaust problem. ( PICS )
I don't know if im just being to picky but I was looking at my injen exhaust the other day and if I stare it at too much I think it looks uneven... kinda looks like the driver side canister is higher.
So I went under today checked the hangers everything looked good and tight.
Has anyone ran into this problem??? what can I do to adjust it?
I Just took some pics.
Old Oct 21, 2004 | 09:39 PM
BKMC's Avatar
BKMC
ur trippin, looks good to me....
Old Oct 21, 2004 | 09:47 PM
thawk408's Avatar
thawk408
I think it has to be like that because of the sway bar.
Old Oct 21, 2004 | 10:58 PM
FairladyZ's Avatar
FairladyZ
Get the tape measure out and see for yourself.
Old Oct 21, 2004 | 11:16 PM
MY350Z.COM's Avatar
The height of the exhaust can be adjusted via the rubber hangars. I had to move them around quite a bit till i got the perfect fit on the Borla. Try messing with the rubber hangars.
Victor
Old Oct 22, 2004 | 02:15 PM
DaddyPhatSaks's Avatar
DaddyPhatSaks
I too have noticed that the driver side tip is angled different than the passenger side. If i look straight at it, the driver side is angled down a little more. Also I seem to be getting a little more black soot on the driver side tip.
Anyone know whats up with that?
Old Oct 22, 2004 | 03:11 PM
maximumsportZ
DaddyPhatSaks
Yup. I fixed it today.
All I did was loosen the bracket that says SES between the pipes just enough so i can have some play... I then jacked up a board to rest on both pipes then, used a level to check on things and once i had it up where i wanted i torqued down on the bolts.
After the needed adjustments:
Old Oct 22, 2004 | 04:04 PM
DaddyPhatSaks
Damn....looks good! I have to adjust mine asap. Thanks!
Old Oct 22, 2004 | 04:21 PM
Annual's Avatar
Annual
Mine sit close to the inside of the bumper. Im lucky it doesnt touch but its close.
Old Oct 22, 2004 | 04:36 PM
thunder0880's Avatar
thunder0880
Yes, you must loosen the bolts and then raise the canister then retighten. If you dont do this then your exhaust will eventually start to rattle against the frame. This is what happen to me in the past.
Old Oct 22, 2004 | 11:31 PM
FairladyZ's Avatar
FairladyZ
turned out great!
Old Oct 23, 2004 | 01:44 AM
ROME's Avatar
ROME
Im in line hold on.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
