Why can't I just use MT-90
Old Mar 22, 2005 | 06:09 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Default Why can't I just use MT-90
The FSM calls for API GL-4 75w-90 gear oil for the 6MT...and Redline MT-90 is GL-4 75w-90. So why do people mix the MT-90 and MTL for the Z's trans??
Old Jul 1, 2006 | 12:04 PM
Nexx's Avatar
Nexx
i think many just go with mt-90, ive seen no reported problems. i just started doing some research on this matter.
Old Jul 1, 2006 | 12:49 PM
stepuckey's Avatar
stepuckey
I've also just started researching this beaten-to-death subject as I just had my tranny replaced. For some reason I think I'm leaning more toward the royal purple then redline. It seems from my research that not as many people complain about problems not being fixed w/ RP as there are w/ the Redline. (Notchiness, noises, etc.) Still not sure though....
Old Jul 1, 2006 | 12:53 PM
disturbed2483's Avatar
disturbed2483
i've been using royal purple since my tranny was replaced for the 2nd time (about 20k miles) and have not encountered a problem it actually made it shift a bit smoother.
Old Jul 1, 2006 | 12:59 PM
Nexx's Avatar
Nexx
everything ive read about rp tranny fluid has been positive, cant say the same about redline.
Old Jul 1, 2006 | 01:26 PM
disturbed2483
i actually use royal purple in the rear diff as well and its quieted it down quite a bit as well.
Old Jul 3, 2006 | 07:23 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Actually, the FSM calls for API GL-4 75w-85 gear oil. That's why a mix of MTL and MT-90 will bring the viscocity to factory specs. It's also what Redline recommends for the Z.
Old Jul 9, 2006 | 10:20 AM
Tekwon-V's Avatar
Tekwon-V
you can use the MT-90 without a problem. Like dkmura said, you mix em to to bring the viscocity to factory specs.
85 / 90 difference... no biggie. especially if you live in warmer climate zones. don't even bother with mixing... just straight pouring with the MT90. oh and you need a swedish pump to get the job done, lol.
Old Jul 9, 2006 | 10:49 AM
Mike Wazowski's Avatar
Mike Wazowski
I also use the Royal Purple in the tranny and diff. Everything flows like butter
stud_daddy
Oct 3, 2008 07:12 AM
krnzzang84
Apr 21, 2008 05:57 AM
