rearview mirror rattling. what can i do to stop it?
Old Apr 23, 2005 | 09:33 PM
sharingan625's Avatar
sharingan625
Default rearview mirror rattling. what can i do to stop it?
when normal driving, no music.
damn rearview mirror makes this buzzing sound. it sometimes sound like bird chirping. it is driving me insane.
it just stops vibrating when i hold it.
what can i do to stop this? thank you.
-john-
Old Apr 28, 2005 | 11:40 AM
supra crazy's Avatar
supra crazy
same here help!
Old Apr 28, 2005 | 05:05 PM
Machupo's Avatar
Machupo
there is a TSB for this noise -- check the TSBs, print it out, and take to dealer
Old Apr 29, 2005 | 01:59 AM
HOMiEZ's Avatar
HOMiEZ
i fixed the rattle myself, and i have a 800watt sub in the trunk. how i did it? some good old fashioned thick double sided tape. the tsb says to use "clothe tape" which can be purchased from www.performancenissanparts.com for oh.. $20 bucks a roll.... i didn't want to pay that so I just used some double sided tape, it works pretty dam well. how do you use the double sided tape? well just find the tsb for the rearview mirror rattle and instead of using the cloth tape, use the double sided tape.
Old Apr 29, 2005 | 08:17 AM
Tackett's Avatar
Tackett
How bout some good ole clear silicone sealer. Run a bead around the seam. Im going to give it a try here soon.
Old Apr 29, 2005 | 01:21 PM
sharingan625
i can't find this TSB...
anyone got a link to it?
Old Apr 29, 2005 | 01:32 PM
westover's Avatar
westover
Default Mirror rattle
My interior rear-view mirror also had a buzzzzy rattle which would stop if you touched the outside case of the mirror. I took it to the dealer, they drove it around the block and replaced the entire mirror assembly --- no charge----. The only problem I had was that the new mirror was not programmed with my garage door opener code and I ended up almost having to break into my own house. If you have a garage doop opener, take a spare remote with you when you pick up the car. Good Luck
Old Apr 29, 2005 | 02:13 PM
Phatmitzu's Avatar
Phatmitzu
I just stick a small piece of foam between the lower end of the mirror and the plastic housing. No rattle ever since. A 2 min fix.
Old Apr 29, 2005 | 05:43 PM
zedman's Avatar
zedman
I am having the same buzzing sound. Its driving me batty! My car sounds like a hunk of junk with that annoying buzz from the mirror. You guys that have that TSB, I cant find it, maybe I should do it myself. Where have you guys placed this tape, maybe if you have some pics, that wuold be awesome. I am sure that this thread is going to gather some steam, I am sure there are a few of us with this same sound. Thanks.
Old Apr 30, 2005 | 01:36 AM
sharingan625
yeah. where am i supposed to put the tape at? pics please.
Old Apr 30, 2005 | 08:28 AM
NA&CH's Avatar
NA&CH
same here. pics would be goood.
Old Apr 30, 2005 | 08:40 AM
toledo's Avatar
toledo
AFAIK the TSB is for rattles in the wiring harness above the mirror and not the mirror itself. I had that TSB done and it didnt make a bit of a difference. I have not seen any TSB's for the mirror itself. Some people have gotten the mirror replaced, but, same problem crops up again. Your best bet, if the mirror is the problem, is to follow suggestions here on the board.
Old Apr 30, 2005 | 12:27 PM
flynnibus's Avatar
flynnibus
Z Flier
my mirror rattles at the plug in the back of it. Not the wire cover up the windshield (which the TSB is for).
My original mirror was replaced about 2 years ago.. this one was fine till I got my exhaust and the extra rumble and it rattles all the time now. simply touching the plug on the rear of it makes it go away
Old May 3, 2005 | 12:28 AM
350zWarz's Avatar
350zWarz
mine buzzes sometimes too....i need to find that tsb anyone have a link
Old May 3, 2005 | 01:38 PM
sharingan625
seriously. it sounds like i got cricket living in my Z...
Old Jun 26, 2005 | 03:04 PM
sharingan625
i've tried putting in some foam inside the mirror assembly, and the buzzing is now gone.
just open up the mirror housing, put some foam between the mirror and the rear housing.
you WILL scratch the housing when opening, so start opening from the top part of the mirror so you can't see the scratch.
and removing the plastic part that covers the wire helps too.
now that i have high powered subs in the car, slight rattle comes out from the button part of the mirror, but that is barely audible. at least the buzzing is gone!!
good luck.
Old Jun 27, 2005 | 10:15 AM
mtscanlon's Avatar
mtscanlon
I like sharingan625s answer... I opened up the cover a few months ago and put a few pieces of felt (from the local craft shop) on the casing where it snaps together... It made the fitment tight but stopped the buzzing most of the time... I think adding the foam inside is a better idea...
Note, as toledo pointed out: the TSB for the is for the wire harness... that is a different deal...
pslamp32
Feb 8, 2017 09:07 AM
bcoffee20
Nov 19, 2015 06:39 PM
LunchBox20
Oct 20, 2015 10:22 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
