oil press. too high?
Old Jul 11, 2006 | 05:11 PM
2005daytonaZ's Avatar
2005daytonaZ
I just started noticing I am having the same problem...Using Mobil 1 full synthetic 5w-30....I never had a problem when I was driving daily but now i only drive about once a week....and now its acting up...im worried because I'm about to make a 600 mile trip and dont want high oil Psi all the way home.
Old Jul 11, 2006 | 05:40 PM
gNaRKiLL's Avatar
gNaRKiLL
mines been doin this as well, sits at around 40 at idle, jumps to 65-75 psi at around 4500-5000, and then around redline is around or above 95 psi. When its cold it will damn near peg the gauge out took it to dealer they said it was running normal.
Old Jul 31, 2006 | 03:41 PM
Agent4573's Avatar
Agent4573
Anyone got this problem pegged down yet? I changed my oil a few weeks ago and noticed that my cold idle pressure went from 60psi before the change to 90+ after the change. At 2000 rpm cold im at about 110 and any higher it just pegs the guage. Once warm I have about 30 psi idle, but im still at about 115 psi WOT when hot. I used a mobil 1 filter and I had Valvoline semi-synthetic 10-40 in there, went to valvoline semi-synthetic 10-30 with no change, finally switched it out to mobil 1 5W-30 w/ a nissan filter, still no change. So i've ruled out oil and filter as causing it, how did the pressure sensor replacement go and how much are the sensors?
Old Jul 31, 2006 | 04:55 PM
rockinbboy's Avatar
rockinbboy
At 70 MPH, you should be at 2.5k RPMs and oil pressure is at 60 PSI. I thought this was a pretty good check! I am stock btw.
Old Jul 31, 2006 | 05:21 PM
Mike Wazowski's Avatar
Mike Wazowski
That's about right. I run Royal Purple 10w40 and at 70 mph in 6th gear cruising I am about 55 psi
Old Jul 31, 2006 | 08:20 PM
Agent4573's Avatar
Agent4573
yeah, i think im gonna have to tap in an aftermarket gauge and see if its reading correctly. If it is, i have a real strong feeling im gonna just redline the motor when cold and blow all the oil seals, then nissan will be giving a new motor.
Old Jul 31, 2006 | 08:29 PM
RobertH's Avatar
RobertH
its not the gauge....its the oil sending unit that screws in the bottom of the motor. i have had mine changed twice, one time being changed today. i had the same problem as you guys, and it fixed the problem both times.
Old Sep 2, 2006 | 05:08 PM
Ky Z's Avatar
Ky Z
My turn to bring this thread back...
I just switched over to Mobil 1 synthetic, 10w-30. I've noticed my oil pressure is way up there now too. I saw where somebody else asked if the OP has switched to Mobil 1...between that and perhaps a fresh oil change is this pretty common? Or do I need to start looking at the sending unit or the gauge itself?
Old Sep 2, 2006 | 06:40 PM
thirty5ounces's Avatar
thirty5ounces
what is the normal oil psi supposed to be at??
idle
2,000 - 3,000 RPM in each gear
im at around 20-30 at an idle and WOT it doesnt go much over 60-70 psi
Old Sep 2, 2006 | 11:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
don't worry about it... see link in my sig. sorry for my paranoia earlier in the thread, that was several months ago. I switched to 5W-30 by the way, and the oil pressure at WOT seems to have dropped a little bit.
Old Sep 14, 2006 | 11:20 PM
NZDarren's Avatar
NZDarren
I had the same problem.
Started the car and the gauge was pegged out, dropped to about 90 at idle when warmed up.
The dealer placed the oil sending unit (like the above post) whatever the heck that is and it now runs fine.
Old Feb 1, 2007 | 03:36 PM
Ztalker's Avatar
Ztalker
Originally Posted by redlinez33
I beleive my sensor is screwed or at least I hope it is...I was riding home from school (80mi. drive) about 65-70 mph and looked at my oil pressure gauge and it was pegged as high as it could go...so I pulled over and at idle it was around 124 and with the car off but acc. on it was like 90 something. Since I am turbo'd and have aftermarket oil pan..etc. I am a little scared about going to a dealership. Oh and I now have a SES light that on all the time. What should I do? How much are those sensors?
FYI....its your malfunctioned oil sending unit. My oil pressure gauge was stuck all the way to the left lately. i went picked one up at the dealer today and replaced the old one located above the oil filter. You'll need a 24mm open end wrench to remove the old one. The part costs about 78 bucks.
Old Mar 2, 2007 | 05:30 AM
zxpwr's Avatar
zxpwr
how easy was it to replace? did you have to remove the filter and/or drain the oil?
i wonder if it can be repaired.
http://www.courtesyparts.com/Merchan...ode=25070-0405
Old Mar 2, 2007 | 09:36 AM
Ztalker's Avatar
Ztalker
i don't think the sensor is repairable. Its a disposable unit.
You don't need to drain any oil or remove the oil filter. Its located right above the filter. Unplug and remove the old one with a 24mm wrench. Watch out though....there will be some oil coming out when the old unit is removed, not much but just enough to mess up your garage floor. On the scale of 0 to 10, and 10 being most difficult. This job is definitely a ONE.
Old Mar 2, 2007 | 09:51 AM
zxpwr's Avatar
zxpwr
thanks! just checked local dealer if they have the part available.. this is now on my to do list for the weekend.
Old Mar 4, 2007 | 09:24 AM
failsafe306's Avatar
failsafe306
Don't forget the thread sealer!
Old Jul 8, 2009 | 01:18 PM
Bad2dabone's Avatar
Bad2dabone
idle
*more than 14 psi idle
*more than 43 psi 2000rpm
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
