Clear bra repair
During the morning commute a rock took a small chunk out of the clear bra. The gouge is only 1/8" diameter. I certainly prefer this over a chunk out of the plastic. I was wondering if anyone has repaired this material. I was thinking of some liquid/paste that I could spread over the area with my fingertip and that would dry solid. I thought I would try the clear DAP caulk. This is white until dry, then turns clear. Not rubbery silicone. I only want to seal the "wound" so it doesn't peel at this new edge. Any thoughts.
Performance Nissan
Performance Nissan
this is one of the reasons I am very against clear bra's and see them as gimmics...
the clear bra as you know costs alot... and it actually costs more then a new bumper / paint and install...
you cant fix clear bra's... and you cant remove them...
Actually the clear bra is rather easy to remove. I have had mine for almost 2 years, just park in the sun for awhile and just peel it off at a 45 degree angle, piece of cake. The warmer/hotter it is the less glue you leave on the paint. It took about 10 minutes to remove.
The clear bra does take quite a beating and can get ugly, but you know its the bra and not the paint. When I took off the clear bra the paint looked like new.
Major
Major
+1 on removal of clear bra.
They come off rather easy to be honest. Once they are taken off the paint is new just like major said.
A clear bra is one of the best investments you can make to protect your cars front end. I dont have alot of miles on my car but no rock chips whatsoever nor any bug guys that wont come out.
Clearbra is far from a gimmick. I've had a few now, and will be buying them again in the future. I would rather have a clearbra take a beating than my paint. I've never understood this line of thinking where you let your car get destroyed then just "repaint" a busted up front-end later. A high-quality clearbra professionally installed will easily last at least as long as 2 or 3 repaints on a chip-prone car like the Z and won't look like hell along the way. I have had several cars in the past get dings on the hood from larger rocks, the clearbra will help to protect from this too. On cars with aluminum hoods, the ding issue becomes even more prevalent. For the record I've never had a clearbra take such a beating as it had to be replaced because it looked bad. In fact, I've never had to replace one at all. I've never had one fade or peel, or turn yellow, etc. On occasion you'll get a small nick if you take a good enough hit, but you typically can't see them. The main thing to remember when buying a clearbra is that not all material is equal. There is a company locally here called "ClearBra" and theirs sucks. I've seen several now in parking lots that were yellow/brown and peeling, etc. Make sure you get the high-quality 3M film if you buy one. I've always used XPel installers in 3 different states and have yet to be disappointed.
If you're worried about the chip in yours, swing by a local installer and have them take a look. I wouldn't try to patch it with anything yourself. I know all the clearbras I've bought come with warrantys from 3M regarding this very thing.
I agree on the ability to remove just takes a little muscle but then you have perfect paint under it. I have lived with clear bra and no clear bra on the Z and prefer the bra, because even though you can repaint the Z it will still look bad in the mean time.
Although you cant fix it, They can be removed. I have the clear bra on my car, and had to replace one section. I watched the guys remove it and install a new one
Clear bra does cost alot, but its nicer looking on a car then the black bras. Me i wait couple more years to have those section replaced like the hood and bumper bra. The one i have on my car is not gimmic, it works great. I saw a coke can bonce right off my hood and over my car at 60mph and didnt even make a mark.
Cool thing was when i got my car used i had the dealer add the clear bra on for nothing
part of the package
Guest
Posts: n/a
between me my bro and my parents we have clear bra on every car we own.
but i tried taking mine off becasue it was turning yellow and look what happend .
https://my350z.com/forum/showthread.php?t=150815
and on the hood the bra came off but the entire adhesvie layer stayed on and it took me almost 3 cans of 3m adhesive remover to get it all off
ill never have clear bra on another car EVER!!!!!!!!!!
WOW that sucks bro........
Guest
Posts: n/a
both actually
i peeled it off like a sticker from the fenders and it came off fine but when i started to pull it off the hood it left the adhesive. so i used a hair dryer on it but it really didnt help.
my theory is it didnt come off the hood good because maybe the temp from the engine or being directly in the sun made the adhesive melt to the hood. maybe not but that what i think happened
as for the bumper i peeled it off like a sticker too. the other side (which i did first) came off fine and then i did the other side and you see what happened.
so i dont know what the deal was. it just cost me about 270 the fix the bumper and about 4 hours of scraping the adhesive off the hood with a plastic spachala
Guest
Posts: n/a
yeah it did.
i took the hood piece off because i wanted to put my nismo graphics on my hood and i didnt want it to lay half on the bra and half off. if i had to do it over i would have left it on and just but the graphic on top
but its ok now
i had the bumper repainted
yeah it did.
but its ok now
but its ok now
If you had to do it again, would you forgo the clear bra system for a re-paint down the line???
Guest
Posts: n/a
well i got my nismo front bumper a few months back and i decided not to put the bra on it. my OEM bumper had the bra on.
so i guess im gonna go without
thats just my opinion. ive had no promblems with it on any other car
now my C6 had about $600 of the bra and since its black you cant see it turn yellow so im leaving it.
the reason it turned so yellow on my rear bumper is the tire blackner i use on my tires sprayed off on it over time
If your ride did not have it already.... is that a Yea, or a Ney....???
probably ney. just wait till you get so many chips that you cant stand it anymore and just repaint for a few $
Thanks your confirming what I<ve always thaught!
Cheers,
Lou
Why throw away your hard earned money on such expensive gimmicks that are not particularly serviceable nor produce the so-called touted maximum protection?
Well, sorry that happend to you
In the long run, if i didnt get the dealer to throw in the clear bra in the deal, I dont think i would have gottin it. More cost effective to do touch up paint, but not the spot touch up pen, a more proffitional touch up. When you got your Bumper repaint did you ask for a little for touch up work later on?
Guest
Posts: n/a
im one of those guys who will be out in the garage at 3 in the morning trying to touch up little specs with a toothpic(ive found that to be the best method)
and i turns out i usuallly make it more noticeable so i didnt get any extra paint this time i figured it would help deture my tendency to be to obsessive at times.
