Navigation door problem...
Old Aug 2, 2005 | 12:37 PM
rzua5's Avatar
rzua5
Default Navigation door problem...
Hi guys, been lurking around the site for quite some times but this is officially my 1st post Anyways, I've search around the site, but cant find what causes my Navigation door on my 05Z to keep opening. What i mean is whenever i shut it down the car or the navigation door, it pops open after 1 or 2 second. Kind of annoying, as if you can never shut the nav door. I see few members here who got similar problem of the door wont move at all. Any input will be appreciated.
Old Aug 2, 2005 | 01:16 PM
350UZSB's Avatar
350UZSB
Mine did that for awhile...when you turn the car off and when its opening up again you can press the button and it will close. However this also causes the door to stay down and stuck down when you turn the car on again...i had a bunch of problems with mine and just brought it in to the dealer. Got a new motor for the door.
Old Aug 2, 2005 | 01:35 PM
Badmonkey's Avatar
Badmonkey
I don't think the door has any electical motors, isn't it just spring loaded with gears? So having the car on or off shouldn't make a difference. Just take it to the dealer, they will check it out. I had mine replaced because it was rattling.
Old Aug 2, 2005 | 01:45 PM
zand02max's Avatar
zand02max
Mine wouldn't open on my 05. They replaced the entire door and motor!
Old Aug 2, 2005 | 06:10 PM
rzua5's Avatar
rzua5
Thanks for the info guys, really appreciate it.. I guess nothing I can do other than chaning the motor... I wonder if warranty includes the navigation door?
Old Aug 3, 2005 | 11:29 AM
rbaggett1's Avatar
rbaggett1
I have an 03 and the door would not fully open by itself. They replaced out the door and everything works fine.
Badmonkey_1. The 03 and possibly the 04 (someone correct me if I'm wrong) don't have motors built into the Nav Door. The 05+ have the motorized doors.
Old Aug 3, 2005 | 12:59 PM
Badmonkey's Avatar
Badmonkey
Badmonkey_1. The 03 and possibly the 04 (someone correct me if I'm wrong) don't have motors built into the Nav Door. The 05+ have the motorized doors.[/QUOTE]
Thanks for the info.
Old Aug 9, 2005 | 08:20 PM
WangDoodle's Avatar
WangDoodle
I have an early '04 Touring with the nav system. It has the electric door. Neat feature; if you leave the door open, it closes when you shut off the car and opens again when you turn on the car. I (being who I am) like this feature, so I leave it open and let it open and close at least twice a day. I bought my Z in Sept '03. I'm bringing the car in to have the nav door replaced again on Monday (8/15/05). This will be the THIRD time the door has broken and had to be replaced (it makes a really horrible grinding sound and won't open or close when it breaks). Yep, 2 years, four nav doors (Hmm... Does that qualify for Lemon Law?). Anyone else experience this? I've heard that the G35s have an electric door over the nav system as well. Anyone know if it is the same door? So long as it's under warranty I'll just let them keep replacing the door. If it happens enough, they'll change the design. Just closing that feedback loop.
Old Aug 16, 2005 | 01:15 PM
LIdrew's Avatar
LIdrew
I have an 03 without a motor but I think the SPRING is broken becuase it doesn't open when I press the button. This should be covered by my warranty??
Old Aug 16, 2005 | 08:10 PM
rbaggett1's Avatar
rbaggett1
LIdrew. I had the same problem where the nav door would get stuck half way up. It's covered under warranty.
Old Aug 5, 2008 | 07:40 AM
rzua5's Avatar
rzua5
My nav door still go crazy sometimes..
Old Aug 5, 2008 | 07:45 AM
JasonZ-YA's Avatar
JasonZ-YA
ya, there is a thread on disconnecting the motor and making it manual somewhere on the site...if you dont wanna fix it or if its not under warranty anymore..
-j
Old Apr 24, 2012 | 08:09 PM
rjej0208's Avatar
rjej0208
i have a 03 touring and my problem with my navagation door is that it opens by itself with every bump or little dip i go over, i always go slow on dips and it still opens , its not motorized, does anybody else have this problem? do they sell the nav door by itself? its either the door or the part at the other end where the door latches on too.
Old Apr 24, 2012 | 08:36 PM
Waiz's Avatar
Waiz
This is a really old thread that has nothing to do with the issue you're having
Instead you should have checked with Courtesyparts.com and looked at this section:
http://www.courtesyparts.com/350z-pa...5_824_834.html
You would have seen the part# 68520M and by clicking on the part # you would have been taken to the page that shows the cluster by itself
Old Jun 27, 2012 | 04:44 AM
spacer's Avatar
spacer
Can someone direct me to the link showing how to convert my nav door (whcih doesn't work) in my 2004 350z to manual operation?
Old Jun 10, 2013 | 11:22 PM
xXShadowGraveXx's Avatar
xXShadowGraveXx
My door wont shut and its an 04Z idk if its the motor or the car but i need help with it. Should i go to the dealer or does anyone in SD that can help. I just got it yesterday so anyone can help check it out would be great thanks.
TrboMike
North East
Sep 28, 2015 06:36 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Mikey R6
Sep 19, 2015 01:48 AM
roadmax
Sep 12, 2015 05:55 PM
