whining noise when clutch is off, noise is gone when clutch is in
Old Aug 6, 2005 | 06:23 AM
billet350's Avatar
billet350
Default whining noise when clutch is off, noise is gone when clutch is in
okay guys i have this really loud whining noise when teh car is at ideal. When it sits there its sometimes really loud and sometimes quite but the problem is when i press the clutch all the way in the noise goes away.
has anyone experienced the same problem.
thanks
PS sometimes its a struggle to get in some gears, but when i put it back in netural and then back towards the gear it works
i just hit 10,500 miles on my 04
Old Aug 6, 2005 | 06:27 AM
350Zenophile's Avatar
350Zenophile
Do a search for throw out bearing. That should be the culprit.
Old Aug 6, 2005 | 08:09 AM
billet350's Avatar
billet350
yeah i did do a search and saw alot of threads consuring throw out bearing but i didnt know if my whining noise was the same
Old Aug 6, 2005 | 05:36 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
More than likely the throwout bearing
Old Aug 7, 2005 | 06:34 AM
bwilliams's Avatar
bwilliams
More than likely the throwout bearing is causing the noise, since almost every throwout bearing will cause some noise. Ask the dealer flukies or just compare your noise to other Z's. If you noise is much louder, you need a replmt bearing.
Old Aug 10, 2005 | 11:10 AM
billet350's Avatar
billet350
if htey replace the tranny does the throw out bearings get replace too
becuase they are gettting me a new tranny.
Old Aug 10, 2005 | 07:46 PM
bwilliams's Avatar
bwilliams
Not necessary to replace the bearing when you have tranny off. It is, however extremely foolish to not replace the bearing at that time since you will have the expensive part of the job (tranny off) anyway.
It's also a good time to make any clutch/flywheel repairs or upgrades.
Old Aug 11, 2005 | 12:26 AM
style JDM's Avatar
style JDM
well i checked 350z and g35.....
and makes same noise
Old Aug 11, 2005 | 04:35 PM
billet350's Avatar
billet350
can the clutch be replaced for free too u think? or what about hte flywheel
Old Aug 13, 2005 | 02:27 AM
bwilliams's Avatar
bwilliams
If you have the tranny off, the additional labor charges to replace the clutch/flywheel should not be more than about $80. The clutch/flywheel represents about 15 minutes extra work.
Old Aug 13, 2005 | 10:10 AM
billet350's Avatar
billet350
how much would the parts cost?
Old Aug 14, 2005 | 09:09 PM
Beaker02's Avatar
Beaker02
I've been told countless times, the noise is normal.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
