Um...help...I think it might be the fuel pump?
Old Dec 25, 2002 | 07:50 PM
johnlotusboy's Avatar
johnlotusboy
Take it to the dealer thats what the warranties for they'll have to fix it for free!
Old Dec 26, 2002 | 04:34 PM
Boomer's Avatar
Boomer
Originally posted by BlkOnBlk
Yeah....it's at the dealer now....I was just curious if anyone else had experienced anything similar. From the lack of response, I'm guessing that this is an isolated incident.
Did you have a K&N Fliter? Another owner just had the same power loss you described. Too much oil gummed up the intake somewhere.
Old Dec 26, 2002 | 07:19 PM
westpak's Avatar
westpak
SFZCC
I have the K&N and no such problems, but in another car I had that problem and it turned out to be the fuel pump, it would run fine and then shut down and if you waited it would start up again but die a little while later, it was overheating and shutting off.
The problem is that at first they could not duplicate problem because it only happened after a while of driving which you could only duplicate with some time driving or fast driving making the pump work constantly. Hopefully they will find the problem the first time.
Old Dec 26, 2002 | 07:54 PM
Boomer's Avatar
Boomer
Thanks, I'll check it out.
See Wespak post also. Was a fuel pump in his case. I would tell them that also.
Old Dec 27, 2002 | 06:44 AM
Ez350's Avatar
Ez350
I think we might be having the same issue. I'll keep you psoted.
kyin
Oct 15, 2015 05:54 AM
