HEADLIGHt! Help remove??
Old Dec 26, 2002 | 03:10 PM
Mr Fairlady's Avatar
Mr Fairlady
Default HEADLIGHt! Help remove??
Well,.My HID's finally came(Phillips D2R) and I'm ready to hook them, up(yes,base model here),.but have to remove the Bulb and the headlight for that matter--Has anyone messed w/ the bulb's yet? You can't see **** in there(behind the headlight)--but either way,..Who knows how many bolts are holding the headlight in there??
Also,.where are the stock HID ballasts mountd on your Z's??
Please help,..
THANX!
Hope to tackle this by this weekend!
Old Dec 26, 2002 | 08:11 PM
johnlotusboy's Avatar
johnlotusboy
The headlight bulbs are accessed by removing the wheels and the inner fender liners. there is a sealed cover on the back of the light fixture turn it counter clockwise to remove. your original bulb is a H-7 on low-beam so a D2R bulb will not fit in to replace it. The factory ballast is mounted on the bottom of the light fixture.
Find yourself a Factory Service Manual, they are very valuable to answer questions like this.
Old Dec 29, 2002 | 10:23 AM
Wicked4u2c's Avatar
Wicked4u2c
You got the wrong bulbs buddy...
Old Dec 29, 2002 | 07:14 PM
Mr Fairlady
well,..we kind got the bulbs to fit,.but plugged em up(all the plug-in's) and nothing happened(semmed a little tight),..but either way,..how do you run the wires through the circle that twists off??
the bulbs did kinda fit,.but i have no idea how they are run?
Its kinda seems like you have to get them from the factory to get HID's in em',.it sux,.I don't know how your supposed to run them w/ that big *** Plastic Circle thing that you have to take off just to get to the bulb!!
Please anyone w/ pic's of yours,.HELP me!!!
so D2S bulb is the one I'm lookin for then right??not D2R--> someone one a earlier post told me D2r!@!!
Old Dec 29, 2002 | 07:31 PM
rahilio's Avatar
rahilio
let me now how this turns out im very interested in dooing the same to my car
Old Dec 29, 2002 | 08:58 PM
Wicked4u2c's Avatar
Wicked4u2c
I have a base model and changed the bulbs out... the are H7. D2R are for the Xenon (H.I.D.) cars...
Old Jan 1, 2003 | 01:57 PM
shortbusrydaz808's Avatar
shortbusrydaz808
Talking I also hooked it up
I put a 7000k HID kit on both the low beams and the highs. Bi-xenon set-up.
So bright and looks much better than the stock Hid set-up.
Aloha
Old Jan 1, 2003 | 02:00 PM
Wicked4u2c's Avatar
Wicked4u2c
What brand did you get of bi-xenon did you get? Any pics..?
Old Jan 2, 2003 | 07:06 AM
macam308's Avatar
macam308
i have a base model also and want to upgrade to HIDs. for those of you who have upgraded your base model, which HID kit did you purchase and where? any other info such as installation tips, etc. will be appreciated, thanks.
Old Jan 7, 2003 | 05:19 PM
shortbusrydaz808
Default sup
I'll get back to you with the web site to get them at.
I don't know how to post pics on here though
u?
Old Jan 7, 2003 | 05:36 PM
Mr Fairlady
Default send me the pic's!!
mail them to me,.I'll put them up for ya!!
I gotta see what your sayin!!!! THANX!!
Mrfairlady@aol.com
Old Jan 8, 2003 | 09:23 AM
dvlad's Avatar
dvlad
Here are the pics of my Xenon High Beams install.
Mr. fairlady... How did you order your D2R bulbs? being that u have a base model without the xenon, you will need to order from a company that places a D2R bulb in the H7 frame. That way the bulb will fit nicely. I had to do this for my high beams. They are a D2R bulb with a H7 base.
To make the wires go to the bulbs, you will need to make a small hole on the side of the headlight assembly. Then using a rubber spacer/seal run the wires into the assembly. With this rubber boot, you will guarentee a water tight fit.
Short...who was your kit made by? How did you do the install? any pics? Because to teh best of my knowledge, xenon bulbs come in 4200K, 6000K, and 8000K. You attach a pic using the atach file below your post(when your replying to a thread). I would like to see a 7000K high beam.
dan
Old Jan 8, 2003 | 05:33 PM
Mr Fairlady
Default Sold Old KIt!
well the old kit is sold,..now I'm gonna get the same kit Daytona got,..but 6000K not 8000K
Thanx for lettin me know about the drilling thing,..That Answers all my questions,..thought there was a way around that but guess not?
I'll have to get the ol' Dirty Dremel out for that!!
But new Kit will be here Soon,...
Thanx for everyting
by the way,.my old kit was Phillips Ballasts w/ D2R bulbs not sure of the Kelvin but its more about the housing itself(from what I found out) then the Kelvin anyway,..kelvin pretty much tells you the Briteness---and I like Purpleish Blueish look not so much Real brite white,.. bulb wise it was not to hard to make them fit,.just the harness where they plugged up didn't feel right either BUt thats cool,.I sold em,..
Thanx guys
COLLIN
Old Jan 8, 2003 | 05:42 PM
Mr Fairlady
Thanx for everyting
Thanx guys
COLLIN
Old Jan 9, 2003 | 07:55 PM
shortbusrydaz808
Default here's the site where I got my hid
http://www.misterjung.com/
Old Jan 10, 2003 | 07:28 AM
macam308's Avatar
macam308
shortbusrydaz808:
is the hid kit from misterjung.com truly plug and play? no drilling in the headlight housing? let me know, thanks.
Old Jan 10, 2003 | 01:14 PM
dvlad's Avatar
dvlad
Originally posted by macam308
shortbusrydaz808:
you will have to drill the headlight housing. there is no way around it. Nissan engineers designed the headlight assembly as one unit. With an access panel to service the bulbs.
dan
Old Jan 11, 2003 | 06:57 PM
shortbusrydaz808
DVLAD is right, no way around the drilling. but it seals up easily with a rtv type sealant.
no worries.
these are the best kit's that I have seen though for a really good price, being that it is hella ballast and phillips bulbs.
just my opinion, I'm no expert.
I also had to file out the headlight housing a lil bit for the highs to fit properly. but low beam fit perfect
I got the high beams from HIDS4LESS.COM
I Do Not reccomend them
Much inferior product
ALOHA,
time to surf
Old Jan 11, 2003 | 07:31 PM
Mr Fairlady
Default tell me this>
Where is the best part to drill??
What am I suppsed to be drilling for,.. and I don't have to take anything apart as far as the HID kit(ballast) goes righ??
Please hook me up w/ that Nad I can take it from here...also whats the best Sealant to use to seal around the hole w/?
THANX AGAIN guys!!!
Old Jul 14, 2004 | 09:46 PM
herbrock17's Avatar
herbrock17
For my 2004 Touring Z, do you guys reccomend www.mrjung.com for purchasing 6000K/8000K D2R replacement bulbs...I'm not a big fan of the OEM 4200K Xenon HID's...I would rather prefer a blue'er color (although I understand it's not as "functional" as the OEM bulbs) to match my Daytona Blue exterior. Please post your recomendations as to whether I should go for a 6000K, 7-7500K, 8000K bulb to achieve that blue color, where you got the bulbs from, if I get the D2R is it really plug and play (no adapters, etc)?? Thanks!!
I have been also looking at www.hidking.com , and www.plasmagarage.com .....HID King retails the "Volcano" brand bulbs for the cheapest price online/and on eBay $135/pair. Plasma Garage sells some 8000K blue D2R brand bulbs for like $190/pair...thanks for your input all!!
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
JGee450
Sep 30, 2015 04:32 AM
