Pump Cutoff??
Old Dec 28, 2002 | 11:28 PM
alphared's Avatar
alphared
Default Pump Cutoff??
I seen in other post that people have tried to fill their gas tank but gets cutoff at half a tank. I just found out I had the same problem. Has anyone found out the reason behind this??
Old Dec 29, 2002 | 08:18 AM
Moroccan_Mole's Avatar
Moroccan_Mole
ive now had problems pumping gas about three times.
now im pretty sure that what causes the tank to cut off at half tank is because the car is tilted/inclined towards the passenger side.
every time ive had a problem this has been the case. when i moved to a level area or where the car was tilted the other way, after that, i've never had any problems.
Old Dec 29, 2002 | 08:32 AM
ares's Avatar
ares
Veteran
2000miles and Ive never experianced such a problem.
Old Dec 29, 2002 | 11:14 AM
alphared's Avatar
alphared
I have 200 miles and i got this problem. Tank is half full and fuel pump clicks off when I tried to fill it. I thought it was the angle of the tank too. Have to try filling it again once the snow clears. But I did find a thread about this here, and seems like alot of people have this problem too, yet no one got a real solution for this. And yes I know how to pump gas.
Old Dec 29, 2002 | 12:19 PM
2003z's Avatar
2003z
have had the problem in both the Z and G, but not everytime.
Old Jan 21, 2003 | 04:03 PM
Pedal Pusher's Avatar
Pedal Pusher
Default Can't fill the tank
My tank will only go about 3/4 full. I have only put fuel in it two times and it has happened both times.
Old Jan 21, 2003 | 04:43 PM
2003z's Avatar
2003z
I found if I hold the pump handle upside down, the fuel goes in with no problem at all, it just doesn't cut off til it starts to ooverflow, so you have to watch it.
I figure that maybe the filler neck curves up, while the pump nozzle curves down and that is what causes the prob.
Old Jan 21, 2003 | 06:31 PM
DriveI65's Avatar
DriveI65
I've had the pump shutoff if I run it too high. Now I put it on the lowest setting and watch the traffic go by and the tank fills up.
I expect that it is a combination of several shrewd guesses in this thread. The fill pipe curves just right to back up to the nozzle and shut off. The other about being on a level surface is pretty good also and it could make the problem worse.
Old Jan 22, 2003 | 04:29 AM
jeffa55's Avatar
jeffa55
I have not had this problem with my Z, but I have had it with my 87 Acura Integra and my 78 Pontiac. Both cars required either playing around with the angle of the filler (maybe holding it upsidedown) or just pumping at 1/2 speed. I believe it has to do with pressure building up in the tank causing the gas not to flow in smoothly. This is not a problem with just our Z...
Old Jan 22, 2003 | 03:00 PM
alphared's Avatar
alphared
Well seeing how there was no snow on the ground today, I decided to go fill up my tank. AND it actually did!. I think theres something about that pressure thing jeffa55 mention, cause when it first happened I was driving it a bit then filled up. This time I drove straight to my gas station and turned it off for about a min or two and it filled with no problems.
Well have to see when the weather is warmer if it'll fill up again.
Old Jan 22, 2003 | 03:58 PM
vova151's Avatar
vova151
Had it happen to me once. Once.
kyin
Oct 15, 2015 05:54 AM
TrackFiddy
Sep 24, 2015 11:40 PM
