TSB Warranty Question?
Old Oct 31, 2005 | 05:14 AM
Poison123's Avatar
Poison123
Google Bot
Default TSB Warranty Question?
If my car is out of the warranty period....will they still perform the TSB's for free?
Old Oct 31, 2005 | 09:34 AM
DavesZ#3's Avatar
DavesZ#3
Yes and No.
Some TSB's have a mileage/time limit on them - the tire feathering TSB for example. Some safety & emissions related TSB's may never expire. I recently got a brake hose related TSB performed on my Toyota that had almost 100K miles on it.
The bottom line is that it all depends on the TSB and what limits Nissan imposes. Call a dealer, they can tell you for sure.
Old Oct 31, 2005 | 01:03 PM
Poison123's Avatar
Poison123
Google Bot
Stupid window motor died in my passenger door and i'm out of my warranty period by 600 miles.
Old Oct 31, 2005 | 03:12 PM
failsafe's Avatar
failsafe
....for your health
Same here. Window and axle click. I'm at 40K. If you check into this with your dealer please post a follow up here, I'd be interested to hear if it's covered. I'll do the same if I get there first.
Old Nov 1, 2005 | 01:42 PM
grifferjr's Avatar
grifferjr
window motor is definately something that only falls inside of the OEM factory warranty. I know cause this is exactly what happened to me. I even have the "gold standard" extended warranty and its not even covered under that.
a dead window motor plus install at the dealer is going to run you around 500 bucks + or - some change. what i did was do some searching both here and on ebay and found a window motor from a person parting their Z out and got it much cheaper. then went to an independant mechanic and paid them to install.
i want to say that for what nissan wanted to charge me upwards of 500 bucks for, i had done for a total of 150-160 bucks. i think i paid around 120-130 for the motor and about 40-50 bucks on the install.
good luck
Old Nov 1, 2005 | 02:18 PM
Generally no, but there are exceptions:
1. If you brought an item to Nissan’s attention, and they ordered parts. The parts will be installed when they arrive regardless of your mileage.
2. Same problem - multiple accordances. If you had a window motor replaced, that motor is (usually) guaranteed for an additional 12 months or 12,000 miles.
3. An item which your brought to the attention of Nissan, but they took no action. Lets say that you took the car in for transmission problems twice: once at 50 and again at 55,000 miles (in warranty). On both occasions Nissan says “The transmission is fine. There are no problems.” At 65,000 miles (out of warranty) the transmission MUST be replaced. You’re asking for a warrantee repair for a “pre-existing problem.” In this situation, I would push Nissan for a free repair.
Old Nov 1, 2005 | 03:10 PM
MCopare's Avatar
MCopare
Just went to the dealer today for the two problems above (Window motor and axle click). Dealer wanted $524 to fix the window motor and could not even quote me on the axle because he said he could not get my car on the lift. I cannot wait to see what they did to my body kit...probably scratched to hell if they tried to get it on the lift without using 2x4's like I recommened. This was in VA by the way.
Old Nov 2, 2005 | 06:25 AM
Poison123's Avatar
Poison123
Google Bot
Ya I think I'll go the "I'll Fix it my damn self route" now.
Old Nov 2, 2005 | 09:22 AM
pargion's Avatar
pargion
good luck
wait, the factory extended warranty doesn't even cover the windows? what's up with that! I have the gold standard extended warranty and I thought I was covered for everything that the factory warranty covers...what the hell did i pay for?!
Old Nov 2, 2005 | 09:50 AM
grifferjr's Avatar
grifferjr
the extended warranty covers everything mechanical on the car that is required for the cars essential operation. anything that has to do with the engine, drivetrain, or wheel and axle system. anything extra on the car is not covered. what falls into this category are the window motors, wiper assemblies, and even the a/c and climate control system are not covered in the extended warranty.
i was uber pissed myself when the motor wasnt covered but i fortunately/unfortunately had an electronic throttle control acctuator go out on me which would have been 850 plus dollars to repair outside the warranty and thank god the extended warranty covered that. so i did get use out of it and it quickly erased the window motor incident from my memory.
Old Nov 2, 2005 | 10:25 AM
pargion's Avatar
pargion
just called nissanusa about what's covered under extended warranty and they did not have a clue as they were just reading off a script. they told me to contact the dealers because they would know more. i asked them what was NOT covered under extended warranty that WAS covered under factory warranty and the guy talked for a good 2 minutes. I responded with, "so you just don't know." and he was like "yeah, i don't have the specifics." But I asked to have their '1500 component covered items' sent to me so i know exactly what is covered. freakin nissan.
Old Nov 2, 2005 | 02:13 PM
grifferjr's Avatar
grifferjr
yeah in fact when you read the terms of the warranty they are just as vague. in the section of "what is not covered" it says the catch all phrase, "anything that is not listed as what is covered". this way they can skirt any argument that a customer has.
even if you go to the dealer they will not be able to know for sure either. what they will do is bring the car in, diagnose the problem, so they can charge you the diagnostic charge. if the warranty covers it you dont have to pay the diagnostic charge but what they will tell you at the dealership is that different warranties are different so they can call and then tell you that its not covered and then you have to pay the charge, a racket!!!
so save yourself the hassle and just assume the window motor is not covered because it is not.
issyz
Jul 2, 2017 03:04 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
