clicking noise from suspension
Old Nov 17, 2005 | 07:45 PM
angelzhope720's Avatar
angelzhope720
Default clicking noise from suspension
There is a clicking noise coming from somewhere on my suspension, I believe. Whenever I'm on the highway it's very noticable, otherwise it's hard to tell. Maybe somethings loose on my wishbone? By the way I only have 3300 miles on the Z. Thanks for any help.
Old Nov 17, 2005 | 07:55 PM
andrew's Avatar
andrew
sounds like rear axle splines, but I only heard mine driving around town, usually in low gears. easily correctable and should be a TSB on it. I'll try to pull up info but someone else will have done it by then
Old Nov 17, 2005 | 08:05 PM
andrew's Avatar
andrew
Sorry, could not locate the link, but if you do a search you will find that this is a common problem (I hope it is nothing more). My rear axle clicking was due to loose splines which required removing rear axles, repacking/grease, and retorqueing. It was covered under warranty. I hope yours is no more serious.
Old Nov 17, 2005 | 08:22 PM
andrew's Avatar
andrew
go to www.nissanhelp.com. scroll down to "bulletins." enter your car and the year and it will explain the TSB. hope this helps.
Old Nov 17, 2005 | 08:29 PM
itburns's Avatar
itburns
I have axle clicking, too. I know the TSB but haven't gotten it fixed yet. Is this something that seriously needs fixing that will otherwise lead to other problems? I always assumed that this was just a nuisance, hence my lack of urgency.
Old Nov 17, 2005 | 09:08 PM
andrew's Avatar
andrew
I do not believe it will result in anything damaging--just annoying. Many of us here have driven thousands of miles on it before correcting it on TSB.
Old Nov 18, 2005 | 07:01 AM
NiSmO21z's Avatar
NiSmO21z
Default Noise
Had the clicking noise in both of my rears. Took to nearest dealership and had it fixed. Mine were my CV Joints. Had them replaced.
Old Nov 18, 2005 | 08:39 AM
Fletch69z's Avatar
Fletch69z
Yep, common. Just take it to the dealership.
Old Nov 18, 2005 | 09:10 AM
Soccerprep205's Avatar
Soccerprep205
I have been hearing some clicking sounds as well... but its only when im accelerating (putting torque down i guess) im taking it to the dealership this next wed.(my appointment) i'll let you know what happens (unless you end up going before me...
Old Nov 18, 2005 | 11:55 AM
angelzhope720
I made an appointment for Monday at 3:30. I asked them to look at the clicking noise from suspension, grease stain on windows, and weird noises from clutch... Man I thought 05's were suppose to have no problems.
Old Nov 18, 2005 | 04:59 PM
eddytsi's Avatar
eddytsi
yeah, i have that problem too. i'll get it fixed after i take it out of storage. f
**for the ones that had it fixed** how long did it take at the dealership to fix it??
sometimes it sounds like my frickin axle is going to rip off..
Old Nov 18, 2005 | 06:11 PM
andrew's Avatar
andrew
One day for me: early drop off and late pick up. I had new stopper kit installed (for window grease streak), new d/s window motor installed, rear axle done (loose splines) and an attempt to correct wheel alignment/replace front tires (but needed to order the 18's) all done during that time.
Old Nov 18, 2005 | 08:02 PM
PerfectOddz's Avatar
PerfectOddz
Whenever I drive my car for the first time in the day it always seems to make a short burst of clicking at close to same spot down the street. I may make it 30-40 yds and then I hear a pop-pop-pop and it's gone. Not to return until the next time my car has sat overnight.
What could that be?
Old Nov 19, 2005 | 01:32 PM
GATORZ's Avatar
GATORZ
I've been waiting 6 weeks for the parts to get this fixed. Talked to the dealer yesterday and they have no idea when they will come off back order.
Are most of you just getting the bolts replaced or are there problems with the CV joints? The TSB is only for bolts not CV's.
Dan
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
