HELP WITH TRANNY! 50K MILES need advise
Old Jan 26, 2006 | 06:48 PM
Latingroove's Avatar
Latingroove
Default HELP WITH TRANNY! 50K MILES need advise
I have a 2004 G35 coupe 6MT and my transmission grinds when I shift..
Let me tell you more about my car. I blew my engine and I replaced it
with a used engine that had 20k miles on it. The car ran fine with the new engine but about 3 days later I noticed that my gears would grind when I shifted from 3rd to 4th and two days later I noticed that I would grind on all the gears... I can still drive the car, I just have to shift really slow..
I took the car to the dealership and they checked it out and they told me that I needed a new clutch and a new flywheel, mind you I had just gotten my JWT clutch and flywheel about 8 months (20k miles) ago so I was puzzle..
I thought that maybe when the engine blew it also caused damage to my
clutch etc..
So I then replace my clutch, pressure plate and flywheel (OEM) at a local shop, but then the problem persist.. So now the shop tells me that Its most likely the syncros inside the transmission housing..
My questions are:
1. do you think that when the engine blew at high RPM's that caused damage to my tranny?
2. Do you think my tranny will be covered under my power trained warranty?
I know that the dealer will try to say that I caused the damage since my car is moded..
Do you have any suggestions? tips? advise?
thanks guys
Old Jan 26, 2006 | 07:04 PM
supra crazy's Avatar
supra crazy
how exactly did you blow your motor? VQ's are very strong motors, and have only been known to blow from FI, but thats because of improper install and s.hitty tunes.
Old Jan 26, 2006 | 07:15 PM
J3rzeyFlip's Avatar
J3rzeyFlip
damn alot of problems happening to ur car! Id be scared and really really worried if it happened to me! Good luck with everything man!
Old Jan 26, 2006 | 09:42 PM
Latingroove
to make a long story short, I was running at 100 short of nitrous and the
cylonoids failed, thus releasing nitrous when I was on the freeway.
The VQ was no match for that.. One of the rods went out the side of the block..
Old Jan 26, 2006 | 09:55 PM
jinsei888's Avatar
jinsei888
nitrous is the lamest thing ever made for performance cars...
Old Jan 26, 2006 | 09:56 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
if you spray you will pay.. just made this up. you should of checked around if 100 shots was ok the the car. you watched too much F&F
Old Jan 26, 2006 | 09:57 PM
Built2shredZ's Avatar
Built2shredZ
Ouch...
Far as I know the standard warrenty on a G35 is 4 years or 48k miles so unless you got extended warrenty I think your out of luck...
Old Jan 26, 2006 | 10:27 PM
The Brickyard Rat's Avatar
The Brickyard Rat
To much history; get your checkbook out.
Old Jan 27, 2006 | 03:16 AM
SpeedRcr's Avatar
SpeedRcr
on a g its 4 years or 60k and the powertrain is longer than 60k
Old Jan 27, 2006 | 05:12 AM
John@Victory's Avatar
John@Victory
this comes from someone tha knows nothing about racing.
if you really dont know abut nitrous you shouldnt be speaking about it.. i personally sprayed 225 for quite a while. and many many others have done the same. and the car takes 150 like its nothing.
a properly tuned n2o setup is just as safe if not safer than f/i
Old Jan 27, 2006 | 11:39 AM
Latingroove
I made an appointment with the dealership for them to check it out..
Its worth a shot right at having them replace it since they would have to
prove that I did something to damage it.. By the way, the dealership doesnt know that I had the nitrous set up.
thanks
Old Jan 27, 2006 | 12:40 PM
boma's Avatar
boma
Yes blowing your engine will cause damage to your transmission.
I'm not sure how, but when my VW GTI blew its engine do to hydrolock, the mechanic said I had to replace my clutch too. He said oil would have gotten on the clutch and it would slip.
So yeah you're better off just buying a new transmission. They're like 1.5K. See if your new clutch and flywheel are salavagable and re-use if possible.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
