Cold Engine Squeel ??
Old Jan 27, 2006 | 08:33 AM
mcm4me's Avatar
mcm4me
Red face Cold Engine Squeel ??
I have a cold engine Squeel /Whirr. It only happens when its cold outside, the engine is not completely warmed up and is under load (accelerating). It sounds like its in the engine or engine area. Its not a belt squeel sounds more like a dry bearing sound. The squeel gets to a higher pitch when the rpms are increased. When the engine warms up or if its relatively warm out side its goes away.
2005 35th Supper Black w 10k mi
Old Jan 27, 2006 | 03:38 PM
lovetoclown's Avatar
lovetoclown
next time, turn off the a/c and see if it goes away.
Old Jan 27, 2006 | 03:47 PM
seanlaw's Avatar
seanlaw
exton!!! i'm in exton.
make sure you let your Z warm up until the temp gauge starts to rise and your oil pressure is around 90....specially when it's cold like it has been the past few mornings
hope to see you around
Old Jan 27, 2006 | 03:53 PM
seanlaw's Avatar
seanlaw
not sure what the sound is but have had it happen once and never again!!! you should come out to some meets...check out the northeast section of the forum
Old Jan 27, 2006 | 06:58 PM
MurphysZ's Avatar
MurphysZ
I have the same sound, it happens daily and only in the morning. After driving the car I can leave it sit all day at work and it doesn't do it again until the next morning. It's only there for the first 5 minutes or so. Anyone else? any suggestions?
lovetoclown, trust me when I tell you, we are not running the a/c in the north east right now! it's been in the 30's.
Old Jan 27, 2006 | 07:08 PM
lovetoclown
Very funny. The A/C is always on unless you turn it off. My car squeels every morning also, but if I turn off the A/C the noise stops and all is fine when the engine warms up.
Old Jan 27, 2006 | 07:43 PM
seanlaw's Avatar
seanlaw
no this is a non-a/c matter...it probably has to do with the oil not being warmed up enough causing more friction which is the noise (my guess)
i always have my fan/climate control in the off position and if i don't warm up the car to what i said earlier, the engine will squeal.
if i let the car sit until the oil pressure lowers to 90 and the coolant temp starts rising i will not get the squeal....alot depends on the weight you run as well....
Old Jan 27, 2006 | 07:46 PM
lovetoclown
what oil are you guys running? I use royal purple or redline oil and even in single digit weather, no noise other than my a/c belt.
Old Jan 27, 2006 | 07:54 PM
seanlaw's Avatar
seanlaw
mobile one 10w30
too bad the ****-retentive oil analysts haven't chimed in yet....
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
