Oil pressure gauge broke...reads 120+ no matter what
Old Mar 18, 2006 | 12:45 PM
failsafe306's Avatar
failsafe306
Default Oil pressure gauge broke...reads 120+ no matter what
Has this happened to anyone else? I noticed this on the way home from work yesterday. It just is pegged all the way to the right, no matter what. I changed the oil today since I was about due, and while under the car I checked the oil pressure sensor and everything underneath looks good.
Bad gauge maybe, or something else? I'd assume if it was a fuse or anything electrical, the gauge would be sitting at "0", not pegged all the way up.
-Chris
Old Mar 18, 2006 | 01:13 PM
techcontrol's Avatar
techcontrol
The sender is probably bad. It might have gone to full ground allowing a max reading on the gauge. Just think of a analog meter. When you turn the ignition to on does the gauge react the same way? If so, disconnect the harness going the oil pressure sender, if the gauge drops to "0" you have found your problem. If the gauge stays maxed out you have a short to ground somewhere between the gauge and the sender.
Old Mar 18, 2006 | 01:23 PM
failsafe306
Thanks, I'll try that.
Old Mar 18, 2006 | 03:07 PM
techcontrol
Checking in' Have you found your problem yet?
Old Mar 19, 2006 | 08:22 AM
failsafe306
I haven't had the chance to disconnect the harness from the sender, but I did confirm that the gauge reacts the same way with just the ignition on. If it is grounded somewhere, that would suck.
Old Mar 19, 2006 | 08:29 AM
plumpzz's Avatar
plumpzz
Atleast its not something that'd cost u a 100 bucks (new gaugo)
Old Mar 28, 2006 | 07:37 AM
failsafe306
Default Update
I replaced the oil pressure sensor and all is working great
Old Mar 28, 2006 | 06:43 PM
techcontrol
I'm glad you found the problem and it was not costly.
Old Mar 29, 2006 | 04:52 PM
redlinez33's Avatar
redlinez33
Hey Ive got that exact problem gauge is pegged out no matter what...did you get the oil pressure sensor from the dealership..or..?
Old Mar 30, 2006 | 09:29 AM
failsafe306
I've already PM'd you back, but just for everyone else reading, I got it from the dealer for 78 bucks, marked down from 90 something Damn expensive little sensor!
Old Mar 30, 2006 | 11:01 AM
BawlZTT's Avatar
BawlZTT
Same issue here, happened on my first run at the drag strip last Wed. When I bounced really hard on my launch. Freeked me out until I called my mechanic to get it diagnosed, he had me turn the key on and it read 65 w/o the car running. I know its the sending unit, but is there anyway to fix it without replacing the unit? It's only $45 from Performance Nissan, but that 2 nights at the track
Also, for the new sending unit, did you use tephlon tape to seal the threads? i am thinking that might be part of the cause for my groundout.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
