please help... my passenger windows is dead
hi,
my passenger windows does not roll up any more. I checked the on/off switch on the driver side, and it still does not go up.
my car is out of warranty. Can you give me any suggestion to fix it? thank you.
luckily mine were all replaced under warranty. i swear i will not buy any more cars with power windows...lol. i'd go to the local nissan wrecking yard and find a used window regulator and replace it myself if i were you. The junkyard usually guarantee the parts they sell. Good luck.
Originally Posted by zzz350zzz
What do I need to replace? How much is the window regulator?
here is a link to try. I did this and it worked, saved me alot of money.
https://my350z.com/forum/maintenance-and-repair/142013-window-motor-repair-replace-motor-brushes.html
If you're out of warranty, first try the repair in the thread linked above. If you aren't mechanically inclined in the slightest, then you could try printing out the thread and take it to a mechanic that you like and have them do it. An hour of labor should still be cheaper than a new motor.
BTW, a regulator is the mechanical track, cables, and gears that raise and lower the window. Yours is probably fine. Most likely, you are having problems with the motor, not the regulator.
Jeff
Jeff
