Bad grinding noise comming from front left brake, plz advise!
A few days ago out of no where when I was driving slowly down a street I heard a very loud sound which was much like a metal on metal dragging. It has happened 2 times since then, and as I pulled into my garage today it seemed to not stop. My brakes never squeaked so I was not thinking it was warn down brake pads, there should be an indicator on them? Maybe it broke off? I have been thinking about throwing on some Hawk HPS to get rid of brake dust, just want to make sure it is not something more serious!
Seeing as though you have a '03, and assuming you've never changed the pads, my guess would be that they're worn down to the warning indicator or worse, they're down to the metal studs that hold the pad to the backing plate.
Sounds just like exactly what happened to my girlfriend's civic, it just started making a metal on metal noise out of the blue. I checked the brakes, and the pads have a little less than 1/8 inch, so I bled the lines which helped brake feel, but not the noise, and told her she needed new pads.
You should have changed the pads at the same time
Originally Posted by HockeyZ39
but it only happens every now and then, I just ordered some pads but its my daily.
Me personaly, every 3 months i visually inspect my car for worn pads, fluids, and so on.
On the contrary, changing pads on the Brembos is a piece of cake. Just pull the pin and spring and you can remove the pads. You need to push the pistons back in and then insert the new pads. For the non-brembo's you have to remove one caliper bolt, pretty easy also.
Well that is good to hear!
Another thing I though was wierd, is the metal on metal sound NEVER happens when I am pushing the brake, only when I am driving at low speeds with no brake applied.
To be honest I'd have loved to, but I'm a newb and don't know how to get into the rear drum brakes. (front disc brakes no problem) I just figured they should all be changed at the same time, and since I didn't know how to do the rears, I thought I'd better just leave it up to the dealer or whatever.
Its self explanitory as to how u disassemble them. DONT mix up the top and bottom spring,but thats obvious by the design of the two.DONT reverse the position of the self adjuster. And put a little hi temp brake lube on the threads of it on reassembly.
Spray everything down good with Brake-Klean. After u do it once u'll be able to do it in ur sleep.
Course if ur power slidin with the E/B or just plain abuse the hell out of them u better learn how to initially adjust the replacements---No big deal but im tired of typing.
Originally Posted by E***zzzzy
Rears are no different than fronts as far as Pad replacement. Unless u drive with ur emergency brake on ALOT !!! the E/B shoes will survive a half dozen pad changes and if u never drive with the E/B on they will prob last for the life of the car. Dont mess with them, just spray them good with Brake-Klean and dab a little Brake assy Lube on the threads of the self adjuster.
Thanks, but I was referring to the rear drum brakes on a honda civic, not the rear e-brake drum on the 350z which I know how to get into.
Vigman
Nov 17, 2015 04:34 AM
