My 350Z does not crank sometimes..help me out
Old Oct 10, 2006 | 11:31 AM
praveen_premraj's Avatar
praveen_premraj
Default My 350Z does not crank sometimes..help me out
I am having this weird problem with my 2003, 6MT 350Z from couple of days. It sometimes does not crank while i turn the key. After a couple of attempts like puttin it in first Gear or second or in reverse gear and holding the clutch it cranks all of a sudden. And sometimes bringing back into Neutral helps.
So do you all think this is a battery issue or the starter issue....i need your suggession.
Old Oct 10, 2006 | 11:34 AM
PerfZ's Avatar
PerfZ
Neutral switch on the clutch would be my guess. You ARE holding the clutch ALL the way in, correct?
Old Oct 10, 2006 | 11:36 AM
tmounk's Avatar
tmounk
I had the same problem with my 03 touring six speed. It only happened once or twice and never came back. I did find out that my battery is leaking. Haven't changed it yet, seems like the leakage stoped on it's own.
Old Oct 10, 2006 | 11:39 AM
praveen_premraj
Thats right...i am holding the clutch ALL the way in....
Old Oct 11, 2006 | 10:10 PM
reppintha510's Avatar
reppintha510
i had my positive terminal loose from the factory causing intermitant no starts!
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
