3rd gear grinding a lot, need help
Old Mar 16, 2003 | 05:31 PM
zogan's Avatar
zogan
Default 3rd gear grinding a lot, need help
My third gear seams to grind a lot. Its not due to my driving, but it happens either when I am shifting faster or spontainiously on easy shifts into 3rd. It only happens on third, no problems on the other gears. Any suggestions????
Old Mar 16, 2003 | 06:15 PM
OKC-Silverstone-Trac's Avatar
Unhappy
Mine is doing the same. I called Bob Moore and Paul is getting the tranny & clevis in so we can replace mine. Call your dealer & they should take care of it 4 U
Bryan
Old Mar 16, 2003 | 06:22 PM
zogan's Avatar
zogan
Bryan
They are going to replace your whole tranny????? did they say what the problem was, has anyone else had this problem.
Old Mar 16, 2003 | 06:54 PM
themyst's Avatar
themyst
Default :(
I wish it were that easy to get a new transmission. Star Nissan would be kicking and screaming before they give me a new transmission... they test drove the car and the damned car refuses to grind... ugh. Anyone in NYC have a dealer aside from Star Nissan that they went to and successfully got a new transmission from? Thanks.
By the way, what are your VIN#'s for the grinding trannys?
There was a poll of VIN#'s earlier and they all seemed to be in the 001-999 range for the grinding trannys... too coincidental I'd say.
Old Mar 16, 2003 | 07:00 PM
zogan's Avatar
zogan
Default Re: :(
I don't know if I can get mine to do it all of the time, but I can get it to do it if I drive it harder, I think my vin is 2931?? Is it the last numbers of your VIN?
Old Oct 1, 2003 | 10:18 AM
gooters's Avatar
gooters
Any updates on this problem? I have been having it for awhile and I want to solve it while under warranty. I have a low VIN# and my 3rd gear has gotten to the point where it will grind first thing on a cool morning even with the clutch to the floor! Even during everyday driving, I tend to grind it ALOT...I have owned several manual vehicles and everyone screws up every now and then, but on fast shifts it seems like I have to conciously think to press the clutch against the floorboard when I shift into third.
HELP!~!
Old Oct 1, 2003 | 10:26 AM
Daytona Blue Z in Bo's Avatar
I got my tranny replaced and the inproved clevis pin installed back in July for grinding that always happened on high RPM shifts from 2nd-3rd and sometimes at random times. It got to the point where I could literally push the clutch down flat to the floor and not be able to get it into any gear at times. I demonstrated this to the service manager and his grit his teeth and asked no questions.
My dealer ordered the new and "improved" tranny and let me know when it was in (about a week) dropped it off in the morning, picked it up that evening and it was better then new. The gear changes are deffinatly more crisp. No problems since.
But I have heard that they might not be do tranny swaps anymore shortly (heard this back in July) because it was getting too expensive and they were just gonna ship out parts for replacement. That means opening up your entire tranny!
I got mine done just in time.
Old Oct 1, 2003 | 10:41 AM
gooters's Avatar
gooters
Old Oct 1, 2003 | 01:06 PM
Jsn350Z's Avatar
Jsn350Z
So...does 2004 have that "new and improved" tranny?
Damn, that would be nice.
Old Oct 1, 2003 | 03:06 PM
koolzero's Avatar
koolzero
Mine has been grinding in 3rd occasionaly. I've got over 13,000 miles. I hope that's not true that they're only repairing transmissions now and not replacing them. But mine isn't grinding enough to get it repaired/replaced, it happens once every 1 or 2 days.
Old Oct 1, 2003 | 07:39 PM
smcgee1970's Avatar
smcgee1970
The synchros in the trannys are defective. The only fix is a new transmission and clevis. MAJOR design defect. Yet another in a long line. Mine did it in 5th gear. Last straw...I traded out. Known Nissan issue. You won't have a problem getting a new tranny. Call NNA and file a complaint, then go to the dealer.
Old Oct 1, 2003 | 10:51 PM
ssk0771's Avatar
ssk0771
I am having problems with my 2nd and I got a new tranny and its still doing the same.
Old Oct 3, 2003 | 05:34 AM
Thats exactly how mine started, then it got progressivly worse
Old Oct 8, 2003 | 12:44 PM
BlueBlur's Avatar
BlueBlur
Yep Tranny problems here too I had to get NNA involved to get the dealer to fix and it started out 2nd-3rd only the 1st pass then got worse. This is my 1st tranny, so we will see. I have about 19k miles on my car last 4 VIN is 8133
MAsSIVrOOM
Oct 20, 2023 10:50 AM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
