Brake light acting up
Old Dec 11, 2006 | 11:08 AM
Bottled Water's Avatar
Bottled Water
Default Brake light acting up
Last night i was coming home from work and my brake light indicator was on while i was driving . now i messed w my e brake to see if it was still engaged a bit but it wasnt. it stayed on for about 2 miles then turned off. iv noticed also under heavy breaking it turns on for a few seconds . i also dont hav an owners manual, and the and i hav hard feelings for the dealer(long story) so im turning to the boards.
Old Dec 11, 2006 | 11:13 AM
roast's Avatar
roast
Brake fluid is low - most likely because your brake pads are getting worn. Check the pads before even thinking about adding more brake fluid.
Old Dec 11, 2006 | 11:14 AM
blazefast's Avatar
blazefast
I don't know about the Z specifically, but this usually means you're low on fluid, or you have a problem with your brakes
bailey bill's Avatar
bailey bill
1) Your "brake light indicator" serves 2 functions. It alerts you that the park brake is engaged, and it also alerts you that you brake fluid reservoir is not full. This can result from a leak, or more likely, the wearing in of your brake pads. Check the fluid reservoir and top off.
2) You can get an Owner's Manual from any Nissan dealership, or order one direct from Nissan.
bill
Old Dec 11, 2006 | 11:15 AM
CaliTouring's Avatar
CaliTouring
Check your pads since youve been doing alot of hard breaking
Old Dec 11, 2006 | 11:18 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I had this problem recently. Soon, that BRAKE light will also trigger the VDC and SLIP lights. That just means that you're low on brake fluid or your pads are worn.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
