Blinker Lights (searched already)
Old Dec 21, 2006 | 05:36 PM
bam025's Avatar
bam025
Default Blinker Lights (searched already)
Ok....Left Blinker Light blinks really fast, and right blinker light blinks normal. Any input...thxs drew
Old Dec 21, 2006 | 05:42 PM
stein's Avatar
stein
Check all your lights, something is burned out. That usually happens when something is else it burnt out.
Old Dec 21, 2006 | 05:43 PM
zand02max's Avatar
zand02max
Have to say this, but did you check your blinker fluid?
Old Dec 21, 2006 | 05:52 PM
Nic@CiNcity's Avatar
Nic@CiNcity
One of your lights is burned out.
Old Dec 21, 2006 | 06:36 PM
Netko350Z's Avatar
Netko350Z
dammit I was going to say that too...
Old Dec 21, 2006 | 06:38 PM
hr2burn's Avatar
hr2burn
OR you recently changed a bulb and it's the wrong size/ voltage. Hence why people use resistors when they switch to LED's
Old Dec 21, 2006 | 06:39 PM
UGOTZ'D's Avatar
UGOTZ'D
maybe the muffler pump went bad?
Old Dec 21, 2006 | 08:33 PM
bam025's Avatar
bam025
Fack....the blinker fluid was empty...thxs smartaces...drew lol
Old Feb 2, 2007 | 09:02 AM
Octogoogles's Avatar
Octogoogles
My blinkers are working normal, but it stopped making a ticking noise...... kinda weird aint it?
Old Feb 2, 2007 | 09:04 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
When you go to replace it you should use the xenon blinker fluid. I hear it makes the bulb appear clear in your headlights too.
Old Feb 5, 2007 | 06:42 AM
DJMatrix1067's Avatar
DJMatrix1067
ya burnt out bulb. when they change it, have the, top off the blinker fluid as well as the flasher fluid. those two are always runnin out on me.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
