30k miles on my Z and got a Check Engine Light.....
Old Jan 5, 2007 | 05:10 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
mine was for a loose gas cap...oops
Old Jan 9, 2007 | 12:03 PM
noel's Avatar
noel
Just got back from autozone and mine read P0456 evap emission control system leak very small...Any suggestions to what i have to check or fix...Im running w/AME cold air intake for 3 years now..need help..thanks
Old Jan 11, 2007 | 05:26 PM
TunaRollZ's Avatar
TunaRollZ
must be a pretty recent code list...
* P0245 Supercharger Bypass Valve Control Solenoid Valve
PS - love the O2 sensor Heather codes Heather problems are annoying
Old Jan 12, 2007 | 09:12 AM
Formulajon's Avatar
Formulajon
If you have test pipes and the sensor is conected then you will get it at on 04.5 and up they register a leak and all it is is that your snesor is reading too much emissions so it isn't a worry. what you can do is pull out the fuse for this one which is I believe number 15 and it will get rid of it but the engine light will come on if anything else is wrong.
Old Jan 12, 2007 | 09:53 AM
noel's Avatar
noel
I don't have test pipes but i'll try to pull out fuse 15 and go back to autozone and clear the check engine light and i'll have to see if it'll go back on,if it does,i'll just take it to a shop...Thank u..
Old Jan 12, 2007 | 01:57 PM
Formulajon's Avatar
Formulajon
It is the 15 eng cont. I think it is labbled on the top of the black box. it is the one at the back row of them on it's own.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
