View Poll Results: problems youve had with your 2003 350Z.
Paint
199
28.88%
Transmission
180
26.12%
Tires
281
40.78%
Suspension
121
17.56%
Interior
179
25.98%
Heating and Air conditioning
26
3.77%
4.21%
Radio
133
19.30%
Electrical Systems
58
8.42%
NONE
108
15.67%
I VOTED!
133
19.30%
Multiple Choice Poll. Voters: 689. You may not vote on this poll
Current/past problems with your Z.
Old Sep 3, 2004 | 01:59 PM
  #161
Pit Bull's Avatar
Pit Bull
Juztin, based on your posts, I think you could break any vehicle
Old Sep 23, 2004 | 07:52 AM
  #162
mrbader's Avatar
mrbader
I've had a problem with my starting system. For some reason the car thinks the wrong key is being used so it doesn't start. The computer keeps losing memory and thinks the car is being stolen. 1st time the dealership reprogrammed my keys. 2nd time they replaced the computer. Now on the 3rd try they are finally giving me a new key. I was told that if it happens again to call them and they'll come tow the car. Doesn't sound like fun but I don't want to get stuck somewhere with no starting car.
Old Sep 28, 2004 | 04:37 PM
  #163
'04blackz33tour's Avatar
'04blackz33tour
Default problems
My observations - 2.5k mi.
_ window streak on driver side
_ rattle on dash it seems like it happens at 3k to 4.5k rpm from the 3 clusters
checked everything else, so far so good
Old Oct 1, 2004 | 10:16 PM
  #164
Badfish25's Avatar
Badfish25
anyone have a shifter that Vibrates like CRAZY when excellerating? Test drove one today and it shook so bad it hurt my hand?
Old Oct 2, 2004 | 01:09 AM
  #165
mrbader's Avatar
mrbader
I don't shift til about 5K RPMS and mine is solid... no heavy vibration.
Old Oct 5, 2004 | 09:30 AM
  #166
lunartick13's Avatar
lunartick13
My Z has been 100% truoble free up until the other day, when I went to fuel up and pressed the fuel button and the door did not open. I had to do this 3 times and finnally it poped open.
When I got home I poped the door again, cleaned around it, applied some silicone grease to the tension spring and the selonoid plunger. There that should be good for another year or so. Other than that Zero problems. 8000 + miles.
Old Oct 7, 2004 | 06:43 AM
  #167
PGH350z's Avatar
PGH350z
2003 Touring with 22k miles as of 10.07.04:
Tire Feathering
Suspension Bounce
Replaced Tranny & Clutch Pedal assembly
Replaced Driver's window motor
Replaced Axle Ends and Bearings
Grease streaks on windows
Squeaky seats
Old Oct 14, 2004 | 01:04 PM
  #168
jpenderg's Avatar
jpenderg
My car has had: bad circuit board. Speedometer and tach stopped working b/c of this. Fixed. Transmission that won't shift into gear consistently (bad synchros?) but Nissan dealership won't fix it. It has the rear axle clicking associated with the TSB for part replacement but the tech line refused to do it, lubed the splines instead. Driver side window motor broke, was replaced. Rear window wiper motor burned up, had to be replaced. Gear whine at all RPM's and speeds now. Transmission rattle when pushing the clutch in when no throttle is on (and I mean LOUD... can be heard over radio at its loudest). Tire issues of course, and vibration associated. I have spent more time in the shop with this car than I did in the entire time I owned the 95 cutlass supreme that had 136000+ mi on it that I owned before it. Do NOT by a Z! It is the biggest mistake you will make... unless you have plenty of time to go in and fight with dealers...
Old Jan 15, 2005 | 09:42 AM
  #169
NISMOFO's Avatar
NISMOFO
Default Re: Burning Plastic Smell
Originally posted by topdown-z
Here's one for ya...........
When I turn on my heater on "High Heat" and turn the selector to vent, I smell a sort of melting plastic smell coming from the drivers side, vent on the door. It does not smell like that from any other vent on the dash or the passenger door vent. I opened the door and the smell continues from within the area that connectes to the door.
When I turn the heat down, the smell almost goes away, which leads me to believe there might be something in the vent that leads to the door vent that overheats and smells when the temp is on "high".
I have an 04' Roadster "Touring" model.
Anyone else out there ever experience something like this???
I have the same smell, but I think it might be coming from the engine bay area into the vents. I smelled the fenderwells on driver's & passenger's side...it appears to only be on the driver's side. I then popped the hood and lifted up the cover for the brake master cylinder. It smells electric almost, but I wouldn't know? Then people mentioned burning clutches, but I don't think that's it and it's coming from the wrong area of the car. I could smell it in the car, and then when I rolled down the window at the drive thru I could smell it even more. Someone also mentioned an oil leak on the driver's side of their motor. So the possibilities are endless. Best case scenario, I thought it was the tires. But the back tires don't smell anything like it. Exhaust leak? Heck, I don't know...I think it needs to go back to the dealership.
Old Jan 15, 2005 | 09:44 AM
  #170
NISMOFO's Avatar
NISMOFO
Originally posted by Flamwu
For those who owns the Track model, do you have an independent button to turn off the VDC and the Traction control? I have been wordering from sometimes now about it. Plus the manual makes reference to 2 different buttoms.
I have a VDC button on the lower driver's side of my dash, but I still haven't found the Traction Control button (even though they reference it in the owner's manual).
Old Jan 17, 2005 | 07:33 AM
  #171
mrbader's Avatar
mrbader
My latest issue: Apparently we have 2 fuel sending units in the car... one behind the driver seat where the bose sub would be and one on the fuel pump in the gas tank itself. If you feel like you're not getting good gas mileage any longer or if the fuel gauge is not reading full when you fill up gas you may have this problem. Nissan recommends that both sending units be changed since there really isn't a way to test them. I only had 1 changed since they couldn't get to my other one. They changed my fuel pump that has the 1 unit and it seemed to have worked out fine. they couldn't get to the other unit since my amps are mounted in there and they didn't want to risk messing up my stereo system.
Now if I can just get my key problem to go away!!!
Old Feb 2, 2005 | 09:19 AM
  #172
King Tut's Avatar
King Tut
That manual makes refference to both buttons cause it is a generic manual. They give the same one to the Base owners even though they don't have either.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
