Exhaust Rattle???
Old Jan 6, 2007 | 06:30 PM
fttl's Avatar
fttl
Default Exhaust Rattle???
I have a 2006 base with 13k miles. Under acceleration I hear a rattle that I think is the exhaust. I took it to the dealer and said was "bad gas" but, all I run is Chevron or Exxon 93. They checked the exhaust and said everything was tight. What do you guys think?? Thanks.
Old Jan 7, 2007 | 04:07 PM
highside107's Avatar
highside107
This sounds like the "axle clicking noise" TSB. Is it primarily in 1st gear (faintly in 2nd) when you accelerate? This is a very simple TSB for the dealership to fix; took mine an hour to fix while I waited. Does it sound like the clicking of two spoons or metal against metal? Do a search for "axle clicking" in this forum -- that should help you.
Old Jan 7, 2007 | 09:16 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
I have an aftermarket exhaust and it rattles on my sway bar at idle sometimes.
Old Jan 9, 2007 | 09:05 AM
fttl's Avatar
fttl
Hey thanks. I'll get them to check it out. It clicks all the way to fourth and when when I'm in sixth and accelerate, it will click.
Old Jan 9, 2007 | 09:15 AM
reptile718's Avatar
reptile718
+1 on the axle click if your under warranty simply bring it in and mention that there is a TSB on it which they can look up and know exactly what to do to fix it not costing you a dime. GL
Old Jan 10, 2007 | 02:35 PM
CNT350Z's Avatar
CNT350Z
I have an 06' with 18K miles and the same clicking noise Fttl is talking about. I thought it was in my Borla exhaust but I took it off and installed my factory exhaust, everything was tight down under and the clicking is still there. It is not as amplified with the stock exhaust. Mine sounds like a loose heat shield? I hear it when sitting still, when the rpms are winding down between 1.5k and 2.5k and when accelerating. Anyone have any ideas?
Old Jan 10, 2007 | 02:46 PM
ANXIOUZ's Avatar
ANXIOUZ
With only 18k miles I'd take it to the dealer under warranty
Old Mar 8, 2007 | 12:28 PM
ZSpectrum's Avatar
ZSpectrum
how do i remove the heat shield from the very back of my z. I believe thats whats rattling with my aftermarket exhaust, that or interior panels. Thanks.
Old Mar 8, 2007 | 03:56 PM
Machupo's Avatar
Machupo
I blew out the inside of my driver's side cat and it made noise no matter what i did once the car was on -- but it was very noticeable
Old Mar 8, 2007 | 05:25 PM
Cannysage's Avatar
Cannysage
man, i have the same problem! it doesn't effect performance at all and it rattle when idling and stuff. just went stock on the exhaust.
Old Mar 8, 2007 | 09:11 PM
johnoppa's Avatar
johnoppa
the axle click is gonna be low in frequency and a heat shield rattle is gonna be higher in frequency.
When I get out of my car my exhaust clunks
Old Apr 2, 2007 | 07:12 PM
jkim1978's Avatar
jkim1978
i just bought a 06 base model.. and i just started hearing the clicking sound when i take off from the 1st gear and slightly in the beginning of the 2nd gear.... what is tsb?
Old Apr 2, 2007 | 07:38 PM
tmak26b's Avatar
tmak26b
technical service bulletin, basically fixes for common problems.
Old Apr 2, 2007 | 08:16 PM
jkim1978's Avatar
jkim1978
thanks alot.... i thought the noise was coming out after i installed the intake.... but i guess its not.. i'm just going to print all the forum topics and just take it to the dealer and tell them to read it... thanks...
Old Apr 3, 2007 | 07:29 AM
ANXIOUZ's Avatar
ANXIOUZ
Check this link out but don't panic by the long list. These are just the bulletins Nissan has released for known issues. Not all are critical but if you think you might have an issue, this is the first place you should check to see if it'll be covered under warranty. Most TSB's are.
http://www.nissanhelp.com/Bulletins/350Z/2006/1.htm
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
