Tire pressure monitor
Old Jan 9, 2007 | 08:14 PM
TheZFan's Avatar
TheZFan
Default Tire pressure monitor
couple weeks ago I went to get my rear tires changed and after I got it back I noticed the rear rite tire pressure isn't reading any more its blank even after a long ride I tried fixing it my self but couldn't find any thing. Can somebody please tell me how to fix it or how that thing even works. Thank you !
Old Jan 9, 2007 | 10:17 PM
PDX_Racer's Avatar
PDX_Racer
Double-check that you still have them!
Old Jan 9, 2007 | 10:22 PM
Reality350's Avatar
Reality350
Did you have the shop replace the TPS sensors? If not, they will not display.
Here read this...
https://my350z.com/forum/showthread....&highlight=tps
Cheers,
R
P.S, watch out for the search police!
Old Jan 10, 2007 | 03:40 AM
DavesZ#3's Avatar
DavesZ#3
Damaged sensor? Can't be fixed, sensor must be replaced. Find a used one for sale in the Private Classifieds here. Get it installed then registered to the system by a dealer.
Old Jan 10, 2007 | 03:53 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I always ask if the shop has a tech that is experienced with TPMS. If they damaged it take it back and make them pay for it.
Old Jan 10, 2007 | 04:01 AM
TxNissanGv's Avatar
TxNissanGv
Also, sometimes when replacing tires the TPMS must be reset. Dealership will have a special tool for this.
Old Jan 10, 2007 | 01:15 PM
done12many2's Avatar
done12many2
Good point. They can attempt to program the sensor again without any need for removing the tire.
If that fails, then move on to buying a new one and installing it.
Old Jan 10, 2007 | 09:38 PM
TheZFan's Avatar
TheZFan
Thanks for the feed back !
Old Feb 2, 2007 | 06:12 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Tire sensor
Can the sensors be installed on a aftermarket wheel (Volks GTS)?
Thx
Cesar
Old Feb 2, 2007 | 06:16 PM
DavesZ#3's Avatar
DavesZ#3
Yes, then can be installed on some aftermarket wheels (not sure about the GTS). If they won't fit in the normal fashion (valve stem), then you can use the banding method of mounting them.
https://my350z.com/forum/brakes-and-suspension-diy/186197-how-to-make-your-own-aps-tire-bands.html
Old Feb 2, 2007 | 06:35 PM
CESAROTORRES
Default Thank you!!!!!
THX!
Old Feb 10, 2007 | 08:00 PM
terrasmak's Avatar
How do they work , mine on my drive home lost connection , are they battery powered ??? Can the batteries be swapped out?
Old Feb 11, 2007 | 05:49 AM
DavesZ#3's Avatar
DavesZ#3
There is a battery in each sensor but it's a sealed unit and can't be replaced. You'd have to buy another sensor if it's gone bad or the battery died.
Old Feb 11, 2007 | 01:35 PM
rockinbboy's Avatar
rockinbboy
if you get different sized tires...can the new settings be input at the dealer so it matches properly to your speedometer and doesn't screw up tcs/vdc based on stock settings.
Old Feb 11, 2007 | 02:22 PM
DavesZ#3's Avatar
DavesZ#3
Nope. That's why everybody tries to stick to some "standard" sizes when going from 18" to 19" or 20" wheel. If you keep the diameters close the speedo will be fine. If you keep the stagger close, then VDC/TCS will be fine.
Old Feb 14, 2007 | 09:25 PM
Cheezwiz's Avatar
Cheezwiz
Easier said than done. I work at a tire shop and know what a ***** it can be. Just let them know you are suspicious it was damaged when they did the work., and that you would like to see the sensor personally. They won't be happy about it, but any self respecting attendant will oblige. If they damaged it, you will see cracking in the plastic, or someone tried to cover their tracks and replaced the sensor with a traditional valve stem.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
