Tranny or clutch?
Old Feb 7, 2007 | 04:04 PM
05Blu3z's Avatar
05Blu3z
Default Tranny or clutch?
My car idles normal sounds normal and everything revs normal, just when i try to pull off it just revs as if the clutch was gone and the car will not move. However yesterday nothing was wrong with the car clutch has not been slipping at all and i only have 19xxx miles on the car. Is this really my clutch or could it be the transmission or something else?
Old Feb 7, 2007 | 04:19 PM
Jenna03Z's Avatar
Jenna03Z
sounds like it just wasn't in gear. does this only happen in 1st?
Old Feb 7, 2007 | 04:20 PM
xjongsangx80's Avatar
xjongsangx80
Sounds like your clutch is gone...what do you feel when you stomp on your clutch pedal?
Old Feb 7, 2007 | 04:21 PM
Jay'Z's Avatar
Jay'Z
If clutch isnt grabbing its def the clutch...... get it looked at... oh at 19000 you could def need clutch depending on the driver.....
Old Feb 7, 2007 | 04:27 PM
Jenna03Z's Avatar
Jenna03Z
it could be the clutch but you would think it would be slipping. mine slips occasionally and i have no other problems.
although maybe i'm just not picturing the problem correctly. i would just take it to the dealer...easiest way to find out.
Old Feb 7, 2007 | 04:45 PM
roast's Avatar
roast
When you say the car will not move, do you mean it won't move at all regardless of what gear, like it's 100% in neutral? Clutches typically gradually wear out... they don't generally just stop working one day... sounds to me like its not getting in gear...
Old Feb 7, 2007 | 04:51 PM
05Blu3z's Avatar
05Blu3z
Ive tried all gears, none of them would move the car even an inch. The clutch petal feels the same as it always has. I know its not me because ive driven manual cars before never had the clutch blow out like this, and my rsxs clutch slipped so i know what it feels like for it to slip. I have it going into the dealer tomorrow and they said they're going to cover it under warranty if it is the clutch, but i just want to know what is wrong with me car.
Old Feb 7, 2007 | 05:29 PM
roast's Avatar
roast
Well if you're having it looked at tomorrow... you will know whats wrong soon enough... better than an internet diagnosis anyway...
Let us know what it turns out to be....
Old Feb 8, 2007 | 03:13 PM
arneltec's Avatar
arneltec
Default Life span of the clutch?
I have a DD and it has almost 50k. I just noticed some whining noice today when I press on the clutch. Bringing it in this weekend to the dealers.
Old Feb 9, 2007 | 11:19 AM
05Blu3z's Avatar
05Blu3z
The dealer took the clutch apart and said that the clutch itself shattered and theres barely any wear on the pressure plate therefore it is not driver and a default in th clutch. He didnt want to cover it under warranty because it has 19000 miles on it and warranty for the cltuch goes out at 12000 miles. So i called 1800nissan1 and filed a complaint and they are going to cover it. But any ideas on how a clutch shatters?
Old Feb 9, 2007 | 01:42 PM
Spddracer's Avatar
Spddracer
Usually when they "deface" it has been overheated. Organic linings dont take heat very well. Once they get over heated to many times they tend to come apart which is probably what happend.
Old Feb 9, 2007 | 02:28 PM
05Blu3z's Avatar
05Blu3z
Well theres hot spots on the flywheel is there any way at all the hot spots could cause the clutch to blow like this?
Old Feb 9, 2007 | 02:58 PM
Ztalker's Avatar
Ztalker
^time to replace flywheel clutch and pressure plate.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
