Damn! Over Filled Oil!
Old Feb 16, 2007 | 08:14 PM
plastiketa's Avatar
plastiketa
Default Damn! Over Filled Oil!
I over filled my oil by about a quart, and realized it after going through a tank. After checking the engine out, I noticed a bit of oil around the spark plugs (driver's side only), and I drained the oil and put in the right amount.
But now the oil psi meter is bouncing around (even after a long warmup) starting at 90 then going to 120 at hard acceleration and eventually dropping to 50-60 and then it repeats. Also, there's still a bit of oil around the plugs, but faint.
I'm heading to a shop on Monday but I'm wondering what problems I should be expecting and how long it may take to fix.
Old Feb 16, 2007 | 09:08 PM
rythex's Avatar
rythex
I wouldn't worry about it.. your engine is still running. :P
Old Feb 16, 2007 | 10:06 PM
plastiketa's Avatar
plastiketa
my check engine light didnt go off, which im happy about, but with the oil around the plug and the meter going haywire, it wouldnt hurt to get it looked at (but i guess it would hurt the wallet, *ouch*).
anyway, any gear-heads want to chime in???
Old Feb 17, 2007 | 10:07 AM
plastiketa's Avatar
plastiketa
ttt
Old Feb 17, 2007 | 02:59 PM
Eazzy's Avatar
Eazzy
Chill ---Are u maybe scutinizing the Oil Gage a little too much ? And what was the norm, u are now just noticing ? Let ur motor cool and clean it up with some spray Electic contact cleaner, then keep an eye on it. Seldomly does an over fill cause major probs other than a little extra crankcase pressure (not oil press)that tends to overwork ur CC vent system (PCV)
Dont open the wallet just yet
Old Feb 28, 2007 | 07:52 AM
gothchick's Avatar
gothchick
Also, after you clean the oil leakage with solvent, you can let it dry - then sprinkle baby powder around any suspected areas and you'll see *exactly* where the leak is coming from (if there is one).
Old Feb 28, 2007 | 11:58 AM
VO...'s Avatar
VO...
Administrator
+1. You've probably never noticed the gauge before, but have been noticing it more since the mishap. It's normal for it to bounce up 10 120, then back down to 60 during lower RPMs. It will even go lower once your out of gear and idle.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
