Resetting the ECU...
Old Apr 7, 2003 | 12:41 PM
Static's Avatar
Static
Default Resetting the ECU...
How do you do it in the Z? I unplugged the negative terminal off the battery for like 5 minutes and that didn't do it.. I still have an engine check lite and it didn't clear.. Stayed on as soon as I turned on the car again. I just installed the AEM intake, and my mechanic accidentally put the MAS in backwards and that threw the code... so.. how do I successfully reset the ECU?
Also.. anyone know wehre the OBDII connector is on the Z so I can read engine codes??
Thanks...
Old Apr 7, 2003 | 03:44 PM
Intrepid's Avatar
Intrepid
Already explained in detail below. If fact, almost everything has been discussed before, so it's a good idea to use the Search function.
How to Reset Light
https://my350z.com/forum/showthread....threadid=17618
aarrgghh
May 1, 2022 11:04 AM
bneumann
Oct 7, 2015 12:16 PM
rizzla
Sep 29, 2015 03:58 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
