Difficult to engage first & reverse gear only when car is running
Old Apr 6, 2007 | 09:44 PM
Cloud's Avatar
Cloud
Default Difficult to engage first & reverse gear only when car is running
It is easy to shift into all gears when the car is turned off but it is hard to shift especially into first and reverse gear when the car is running.
What could be wrong? The clutch line has been bled.
Old Apr 6, 2007 | 09:58 PM
Cloud's Avatar
Cloud
this happened after putting in a new clutch btw
Old Apr 6, 2007 | 10:07 PM
plumpzz's Avatar
plumpzz
are you rolling when you try to engage the gears? Reverse gear won't reverse if you're rolling forward. 1st gear is a hard get to get into no matter what.
Old Apr 7, 2007 | 12:26 AM
Cloud's Avatar
Cloud
not rolling. Has much more resistance than two previous clutches I had.
Old Apr 7, 2007 | 05:14 AM
mgtibbetts's Avatar
mgtibbetts
Is it cold outside when this happens? I have the same problem below 50F but it goes away after the drivetrain warms up. Also have aftermarket clutch.
Old Apr 7, 2007 | 10:06 AM
Cloud's Avatar
Cloud
nop not that cold outside. maybe 60-70
Old Apr 7, 2007 | 10:09 AM
This is not good. A clutch adjustment might correct the problem.
Old Apr 7, 2007 | 10:18 AM
Cloud's Avatar
Cloud
clutch adjustment or clutch engagement point adjustment?
Old Apr 7, 2007 | 11:23 AM
plumpzz's Avatar
plumpzz
same thing. I had a clutch adjustment when I had a new tranny. It feels 10X better. Stiffer too and bites differently.
Old Apr 7, 2007 | 11:54 AM
Cloud's Avatar
Cloud
do you mean aligning the clutch?
Old Apr 8, 2007 | 07:37 PM
Cloud's Avatar
Cloud
update: Actually its all gears. I thought it was first and last only because you usually shift into those 2 only after a stop.
Anymore ideas?
Old Apr 8, 2007 | 07:41 PM
Question
Anymore ideas?
Additional Information
cupertino
Year and mileage would be helpful.
Old Apr 8, 2007 | 09:03 PM
Cloud's Avatar
Cloud
Aftermarket clutch
Brand new
Ogura Racing Clutch, single 409 series Dampered, silent , high friction.
installation by Z Car Garage.
Old Apr 8, 2007 | 09:14 PM
Nitrouz's Avatar
Nitrouz
Back to Z
do you mean when the car is moving? Or just idling at a stop?
Old Apr 8, 2007 | 10:55 PM
Cloud's Avatar
Cloud
idling at a stop. e.g at stop sign, traffic light.
I got stuck in the middle of a street a couple of times cause I couldn't get in reverse.
It shifts fine right after I start the car but if i drive the car and then stop, I won't be able to get it into gear easily again.
Old Apr 9, 2007 | 01:13 AM
Machupo's Avatar
Machupo
I frequently cannot get my car into reverse first thing after turning it on when it is colder than 70 degrees outside. One solution that I found is that I shift into 1st and then back to reverse... guess it lines something up just right, because it works every time!
Old Apr 9, 2007 | 01:27 AM
chriskabobbers's Avatar
chriskabobbers
wow that sucks, you probably should invest in a new clutch. good luck
Old Apr 9, 2007 | 07:48 AM
Cloud's Avatar
Cloud
Anyways, getting in first is hard too.
Old Apr 9, 2007 | 11:20 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would change your fluids in the transmission and differential to synthetic.
Also, it's pretty common for it to be difficult to shift into 1st and R when the transmission is cold. Keep in mind the transmission warms up much slower than the engine because it only heats up due to friction.
60-70 degrees F is actually quite cold for a transmission whose operating temperature is actually MUCH HIGHER than that when the car has warmed up. (probably at least 170-180 F)
Old Apr 9, 2007 | 03:00 PM
Cloud's Avatar
Cloud
even after the car has warmed up the problem persists.
