what is the proper way to put my car on jackstands
Old Apr 13, 2007 | 05:13 AM
chamois's Avatar
chamois
Default what is the proper way to put my car on jackstands
i need to do some work and i need to take the wheels off, so i bought some 2 ton jackstands and a 2 1/2 ton trolley jack. i think these will hold the car but im not 100% sure. also when i put the car on the jacks how should i do it, where should i lift and is there any order to which side goes up first?? thanks
Old Apr 13, 2007 | 05:15 AM
QuicksilverZ33's Avatar
QuicksilverZ33
Old Apr 13, 2007 | 05:16 AM
MUZZY's Avatar
MUZZY
do fronts first if u look under ur car there is a 2nd rail further in that u can jack up on and has a perfect with for those jackstands. it is going to be behind the front wheels. then after u jack each side take ur jack and from the rear just jack up the brace in the middle that has the bolt from the pumpkin on it up
Old Apr 13, 2007 | 05:28 AM
chamois's Avatar
chamois
the pic looks like i lift on the diff. is that right or is their something right near it the i use to lift?
Old Apr 13, 2007 | 05:29 AM
QuicksilverZ33
I'de say the diff is fine to use.
Old Apr 13, 2007 | 09:16 AM
VO...'s Avatar
VO...
Administrator
+1^^
For the rear I usually just jack the car up from the pumpkin and leave the jack there, unless I have to crawl under. If that's the case, add some stands to the rear also. You can place the stands under the aluminum spring housing for the rear wheels. I find that place pretty sturdy.
Old Apr 13, 2007 | 10:14 AM
Mazinger Z's Avatar
Mazinger Z
Originally Posted by vo7848
+1^^
That's what I did yesterday since I just put on my Veilside sides (no more space to put jackstands. Is that a reliable place to put jackstands?
Old Apr 13, 2007 | 10:22 AM
chamois's Avatar
chamois
dont mean to sound stupid but what is the pumkin your talking about. ive never heard that term before.
Old Apr 13, 2007 | 11:21 AM
VO...'s Avatar
VO...
Administrator
differential in the middle of the rear axle.
Old Apr 13, 2007 | 11:22 AM
VO...'s Avatar
VO...
Administrator
Very reliable.
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Mattg350z
Oct 2, 2015 06:51 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
