30k Maintenance
Old Apr 14, 2007 | 11:10 AM
hersilverbullet's Avatar
hersilverbullet
Default 30k Maintenance
Just came back from the stealership and was told I am due for the 30K service. I have a MT 2003 Z. How hard is it to do the following?
Replace differential oil (limited-slip, conventional)
Replace engine coolant/flush system
Replace manual transmission oil
Can I do all of these in my driveway? Does anyone have any links on how to do these? I used the search button and had no luck.
Thanks for all the help.
Old Apr 14, 2007 | 11:31 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
didnt search to hard???????????https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
Old Apr 14, 2007 | 01:51 PM
hersilverbullet
That shows me the differential fluid. Sorry for the ignorance here, but does it also apply to chanign out the manual transmission fluid?
Old Apr 14, 2007 | 04:06 PM
tmak26b's Avatar
tmak26b
$75 in parts and 3 hours of time
Old Apr 14, 2007 | 04:31 PM
derekinthez's Avatar
derekinthez
Default Trans fluid
Manuals have transmission fluid?
Old Apr 14, 2007 | 05:07 PM
desiZ's Avatar
desiZ
Manuals = Manual Transmission = YES , there is transmission fluid
Old Apr 14, 2007 | 05:09 PM
roast's Avatar
roast
Yeah... manual transmissions require oil.
Old Apr 14, 2007 | 06:28 PM
bjr's Avatar
bjr
If you are skinny you can just crawl underneath the rear end and follow the change the oil thread located somewhere here. Make sure the car is level and you will do fine.
Kind of the same question. After doing some reasearch on this I have the opinion that if you do it every 30k there is absolutley no need to flush. What I would recommend is to drain it and fill it back up with premixed from the store. Do it about 3 or 4 times in one week and most of it will be changed. Good for you for realizing that you don't leave it in there for 10 years and then have to power flush all the crap out of there if your cooling system survives that long.
Do you have jack stands and are confident that you know the correct places to use them? Then yes on that too. You will be doing the same work you did on the rear end but the car must be up in the air to get under it. Be careful.
If you just don't feel like doing these, just doing these 3 are the most important and should not be quite as steep as the typical delear recommended mile long list. Just decide if you feel safe doing them and you could save some money plus you will know your car better. Always a good thing.
See comments above.
There are only like 4 posts in the repairing and detailing DIY section, how did you miss this?
https://my350z.com/forum/showthread.php?t=131098
jk, BTW Good luck!
Old Apr 15, 2007 | 10:13 AM
hersilverbullet
Thanks guys for the help.
Old Apr 18, 2007 | 03:39 PM
ANXIOUZ's Avatar
ANXIOUZ
Anyone know how much the dealer charges for the 30k service?
Old Apr 18, 2007 | 03:53 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Way too much. According to the Maintenance guild I got from Nissan, the basic 30k is around $469. That includes:
Lubercate all locks and hinges
Replace diff. oil
Drain and replace engine coolant
Replace radiator cap
Replace wipers
Inspect running lights
Remove battery cables and install anti-corrosion pads
Install fuel treatment
Balance 4 tires.
Old Apr 18, 2007 | 03:55 PM
ANXIOUZ's Avatar
ANXIOUZ
Groan. Thanks for posting that. I appreciate it.
Old Apr 19, 2007 | 06:18 PM
hersilverbullet
Yup around $400 not including tax.
Old Apr 22, 2007 | 12:12 PM
billp's Avatar
billp
I was quoted yesterday $230+/- in SE WA state. Maybe they don't do as much.
Old Apr 28, 2007 | 01:51 AM
billp's Avatar
billp
Well, today I was in there for the 100 point inspection to get the warranty transferred and was quoted $499 for the 30K, first guy must not crap.
Old May 1, 2007 | 01:45 PM
BlackSpec02's Avatar
BlackSpec02
Does anyone have the list for the 60K service? I am about due for that and would love to avoid the stealership if possible.
Plus to add to the complications I am supercharged...
Thanks!
Old May 1, 2007 | 01:55 PM
JDMFairladyZ33
Thanks!
At 60k they have a very cheap basic minimum service that's under $100 but it doesn't do crap except inspections. You'll end up getting charged extra for the things they find that needs attention. Here is the service that they actually do something to your car:
  • Luricate all locks and hinges
  • Auto. Tranny service - Drain and fill
  • Replace diff. oil
  • Drain and replace engine coolant
  • Replace radiator cap
  • Replace wiper blades
  • Inspect all running lights
  • Remove batt. cables clean and install anti-corrosion pads. Reseal terminals
  • Install premium fuel treatment
  • Balance 4 tires
All this for an economical price of $469.95.
Old May 1, 2007 | 02:18 PM
BlackSpec02
So I should basically just look into getting all my fluids changed:
Tranny
Differential
Coolant
I may just buy the fluids and take it to a local mechanic since I dont have anywhere to dump fluids and I would rather not transport them in my Z.
What about things like the fuel filter, etc?
JUST NOTICED... the radiator cap... they really replace that? How do you know if it needs to be replaced? I've had my nismo rad cap for 40K+ miles....
Old May 1, 2007 | 02:24 PM
bjr's Avatar
bjr
Tranny
Differential
Coolant
+1 on the fluid dumping. I found out Jiffy Lube takes coolant for free and it's 1 mile from the house but it still sat in the garage for 3 months. At least I didn't have to find the municipal waste department on a Saturday though - and try and go to the other side of town with the junk.
We don't have a fuel filter.
Thanks for triggering my memory though. I need to check on small stuff that can be forgotten. Like do cars still have PCV valves? I don't remember seeing one.
Also, every 2 to 3 years replace your brake fluid if you plan on keeping your car 5-10 years!
Old May 1, 2007 | 02:55 PM
BlackSpec02
No fuel filter.. .good to know. I think I will try and do those fluids in addition to brake and power steering all together...
Any good/recommended differential/tranny fluid or coolant to use?
