Service Engine Soon Light
Old Apr 27, 2007 | 09:02 AM
fonzy's Avatar
fonzy
Default Service Engine Soon Light
Hey guys, how do you get that light to go away. I know there should be a way to reset it.
Old Apr 28, 2007 | 06:45 AM
sgshap06's Avatar
sgshap06
Go to a autozone, they have the tool to do it. You probably just had a loose gas cap..
They will reset it and also tell you what made the light come on.
Old Apr 28, 2007 | 06:50 AM
dedmoonstears's Avatar
dedmoonstears
save your time...reset it yourself ( it involves playing with the ignition/brake and acc pedals ) theres a link somewhere here , i tried to look it up for you but failed...try 350ztech..im sure it in the faq section.
Old Apr 28, 2007 | 08:19 AM
DavesZ#3's Avatar
DavesZ#3
Disconnect your battery overnight or go to autozone and they'll read the code and reset it for you. The throttle-ignition switch trick is too damn complicated.
Old Apr 28, 2007 | 08:38 AM
The CEL light ON may identify a significant problem. Have OBDII read, and see what the code is.
Old Apr 28, 2007 | 06:25 PM
VIZAGE's Avatar
VIZAGE
Find out code first. All I have ever done is disconnect the battery for 10 min. This has always worked for me. I don't know why some people say overnight or one hour to disconnect battery. And there not wrong but I was told 10 min. and it's always work for me. Does anyone know the reason behind this?
Old Apr 30, 2007 | 09:46 PM
fonzy's Avatar
fonzy
Thanks for you input guys. It turned out to be my gas cap. for some reason i have to tighten it more now. Im gonna get that thing replaced.
Old May 1, 2007 | 07:29 PM
LOL. Usually the most simple solution is the best solution.
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
