auto window up/down when open/close door
A while back, some members said that in cold days, sometimes their window won't come down when door opened. Is the problem still there now? It happened twice to me, and it wasn't because of snow and the window all iced up, it's just a cold day.
Also, do you guys find that the window don't go down as much now? I find it that when I first got the car, it goes down fine, and now the window is going down much less than before. So today I went back to the dealer and show them the problem. They also notice the window only goes down a bit, but they said they couldn't reset the window to let it go down more. Because it came from the factory like that, and there is nothing to adjust. They also told me as long as the window still goes down, there won't be a problem. Is that all true? Or the dealer just don't know **** and just BS'in me??
they are BS'ing you... mine did the same. I took it in. They replaced the regulator inside.
After the fix it works like new... but 3 months later I am starting to notice it getting "sloppy" again.
It sure as hell would suck to have to replace the regulator every 4 months.
But is it true that as long as the window still goes down, everything should be fine?
p.s. The car is covered by warranty, I don't understand why dealers lie all the time
Yet I bet if you open your door and then pushed down on the window it will go down another quarter inch or so before it stops.
On mine it seems like the regulator may be working but the windows not following it all the way down.
I had my grease streaks fixed last week and they were supposed to fix that problem also but it still doesn't go down and up like when it was new, I think I will wait and see until a bulletin comes out for this particular problem. As long as it's coming down a little we should be fine.
Man, for a first year car, everything is just waiting and more waiting......
I just realized that I have the same problem. Previously, I wanted to take the car in for the streaks and some rattling issue but was worried they couldn't put it back together properly. I hope there's a fix for this.
The dealer still don't want to touch it till this day. No matter how many times I told them, they only point out to me that the window is still moving.
Now my wondow only go down about 2mm...
I set my calipers to 10mm and told the phuckwad service advisor to open the door as I held the calipers up to the window down by the seal where it meets the door.
when he saw it was only like 2mm he started feeding me some BS ..... he never did fix it.. he told me I'm too picky and he never wants to see my car in his drive again.... I took it to another dealer and they have sorta fixed it... it moves about 7mm now.. good enough I guess.
Originally posted by N74DV
thats the same **** I got from my dealer.... UNTIL I printed out the page in the service manual that says it must move 10mm. I brought that page in along with my millimeter calipers.
Originally posted by aptiva
Can this feature be disabled?
Great news fellas!!! My windows won't go down at all. They started to drag at first then just stop. Luckily it stopped working in the up position. Whew! It's cold in kentucky right now. Anyway, I took it to the dealer of which began another bad experience, and they replaced the window motor (they said). Three days later it did it again. They since have a new window motor to install and my window won't go down. I have an app. next week to have it put in. By the way, The window seems to work when the weather is above 45 degrees.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
