Help!!!!!!!!!
Old May 27, 2007 | 06:53 PM
jperleon's Avatar
jperleon
Default Help!!!!!!!!!
Just tried to install the JWT Popcharger and when i turn on the car it will run for about 5 seconds and then kills itself and throw's the check engine light. Any Suggestions?
Old May 27, 2007 | 06:56 PM
HDPDZO6's Avatar
HDPDZO6
MAF still connected?
Did you damage the MAF?
Reset the ECU?
Shove a potato into the tube before installing the filter?
It would better help if you went thru the steps you took.
Old May 27, 2007 | 06:59 PM
Blk03G35's Avatar
Blk03G35
You didn't reconnect the MAF
Old May 27, 2007 | 07:11 PM
THE TECH's Avatar
THE TECH
Sounds like someone didn't follow all the directions. +1 on the MAF.
Old May 27, 2007 | 07:12 PM
jperleon's Avatar
jperleon
I followed the directions step by step. I disconnected the battery and also if i give it gas it kills it quicker. The MAF is also re-connected.
Old May 27, 2007 | 07:13 PM
Blk03G35's Avatar
Blk03G35
Did you reverse the MAF? Take a picture of your engine bay and the whole assembly.
Old May 27, 2007 | 07:16 PM
THE TECH's Avatar
THE TECH
Did you disconnect the TB? Also, did you ever turn on the car before reconnecting everything?
Old May 27, 2007 | 07:18 PM
jperleon's Avatar
jperleon
the TB? and no i never turned the car on without everything connected. Should i take a picture of the bay and post it?
Old May 27, 2007 | 07:22 PM
THE TECH's Avatar
THE TECH
TB = throttle body
Casanova's Avatar
Casanova
hehehe its gotta look like my 05 touring here
Take a pic of yours.
Old May 27, 2007 | 07:24 PM
Blk03G35's Avatar
Blk03G35
Please take a pic that's closer then the one above...
Old May 27, 2007 | 07:38 PM
jperleon's Avatar
jperleon
Old May 27, 2007 | 07:41 PM
jperleon's Avatar
jperleon
i can take more pics if needed
Old May 27, 2007 | 07:43 PM
THE TECH's Avatar
THE TECH
Looks ok from the pic.
Old May 27, 2007 | 07:48 PM
jperleon's Avatar
jperleon
any reason why the check engine light came on?
Old May 27, 2007 | 07:51 PM
THE TECH's Avatar
THE TECH
Check the codes.
Old May 27, 2007 | 07:56 PM
jperleon's Avatar
jperleon
I'll check the codes tomo. If i clear the codes should it run fine? also if i disconnect the MAF and turn it on i cant rev past 2k.
Old May 27, 2007 | 08:22 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
thanks for the extra info...anyone have something that could be useful to my problem?
Ok , Sorry......I just saw that response and couldn't understand.
I would check out the 02 sensors they might be giving false readings, or there is one not working properly. In any case I think I would try to get it to a dealership for absolute sure.
Old May 27, 2007 | 09:25 PM
THE TECH's Avatar
THE TECH
You'll need to see what the codes are first in order to tell what the problem is. Clearing a code doesn't wipe away the problem. Leave the MAF connected. Of course the car isn't going to run right with it unhooked.
Old May 29, 2007 | 06:48 AM
jperleon's Avatar
jperleon
fixed the problem!! piece of styrofoam was caught in the MAF sensor. thnx
