plenum spacer causing strut to vibrate?
Old Aug 1, 2007 | 08:54 PM
Blazemaster's Avatar
Blazemaster
Default plenum spacer causing strut to vibrate?
I have the Motordyne 5/16" plenum spacer and tried to run it with the OEM strut bar, but there's no clearance between the strut bar and plenum, causing the whole car to vibrate when accelerate. I thought the Motordyne unit was designed to work with the OEM strut bar? I took off the engine cover, but the plenum is still touching the strut. Is the OEM strut bar compatible? Do I have to go with a aftermarket strut that's made to go in front of the plenum?
Old Aug 1, 2007 | 09:02 PM
IndyZ-man's Avatar
IndyZ-man
I sure hope not. I just placed an order for the same thing. From what I've heard before, you might be able to play with the adjustments on the strut bar to give yourself some clearance. Good luck!
Old Aug 1, 2007 | 09:12 PM
NGZ's Avatar
NGZ
Is there supposed to be a spacer for the strut bar?
Old Aug 1, 2007 | 09:35 PM
IndyZ-man's Avatar
IndyZ-man
According to pics in this thread http://www.my350z.com/forum/showthre...t=strut+spacer there are some spacers for the strut bar.
Old Aug 1, 2007 | 10:03 PM
VicPham's Avatar
VicPham
Lifetime Member
I have mine installed with no problems. I know that there is a spacer that goes under the strut bar to give it clearance from the plenum.
Did you do the install yourself or did an auto shop install the spacer?
Old Aug 1, 2007 | 10:28 PM
Blazemaster
I guess that's what I get for buying used, there's no spacers for the strut bar included with mine. Time to go get something from Home Depot I guess.
Old Aug 2, 2007 | 01:53 AM
VicPham's Avatar
VicPham
Lifetime Member
If you have a ace hardware there, then get a 5/16th spacer for your strut bar.
For the time being just remove the strut bar for now.
Old Aug 2, 2007 | 05:26 AM
HondaKiller's Avatar
HondaKiller
you will need 2 to 3 spacers for each screw. Not the biggest deal, might cost you $3 for all them.
Old Aug 2, 2007 | 05:36 AM
03performz's Avatar
03performz
That sucks. You need the strut mounting spacers. Screw the home depot sht. Call Motordyne and just get theirs. The guy seems to be really cool. I'm sure he'll accomodate you. They're aluminum and really light.
Old Aug 2, 2007 | 06:07 AM
Few members get into trouble with similar installs because the try to force things to fit. An example is stripping the bolts that attach the strut brace to the body. You should be able the thread the bolts by hand.
The height of the brace has some play. Loosen the locking nut. Turn the other nut to increase-decrease tension. The brace will move up and down. Tighten locking nut.
Old Aug 3, 2007 | 05:00 AM
bommart's Avatar
bommart
+1.
Old Aug 3, 2007 | 05:30 AM
Villa67's Avatar
Villa67
+1 on playing with the adjustments on the strut bar. That's what it was done with mine and it works perfect.
Old Aug 4, 2007 | 03:44 PM
darbyhouse's Avatar
darbyhouse
Here is a link to the Motordyne spacer / MREV2 installation guide. This should help you out as well.
http://www.motordyneengineering.com/manual.pdf
wanderingstuden
Jan 28, 2016 07:03 PM
_bit
Oct 2, 2015 07:49 AM
