2nd gear grind when fast shifting
Old May 11, 2003 | 08:33 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default 2nd gear grind when fast shifting
When I shift from 1st to 2nd gear real fast, the tranny grinds during the shifting. Is this a problem with tranny? I can avoid the grind if I shift little slower, kind of ease in the clutch then shift to 2nd...
All other gears are fine. 2nd to 3rd, 3rd to 4th, and so on..
Does anyone else having the same problem?
Old May 12, 2003 | 04:08 AM
zpeed350's Avatar
zpeed350
shifting into second slowly when the temp is below 50* in the morning is a problem. when the tranny and engine are cold. other than that i do not have any grinding once the car is warmed up. not sure what to do about it yet.
Old May 12, 2003 | 06:41 AM
vancitydude's Avatar
vancitydude
shifting into second is the one and only complaint about my car.... it's horribly inconsistent... sometimes it's fine... sometimes it's an all-out grind... i had it in for servincing once and they said to let the car break in further before they do major surgery. I'm not convinced.
Old May 12, 2003 | 06:57 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
yea, mine is same thing. not consistent. I did however changed to MTL/MT-90 mixature of Redline Tranny Oil about 4-5months ago, but it didn't help that much for me..
guess I'll wait until it gets worst then take it to service dept. to have them look at.
Old May 12, 2003 | 07:57 AM
zpeed350's Avatar
zpeed350
Well said. Second if very inconsistent. No grinds or problems anywhere else.
Old May 12, 2003 | 09:17 AM
icepop456's Avatar
icepop456
I have the same exact problem. As someone previously mentioned, I'm going to wait until the break in period is over before I have someone look into it. The shifting is definitely different than my MR2 Spyder was.
Old May 12, 2003 | 10:40 AM
chahny's Avatar
chahny
How many miles do you have on your car?
I have 5500 and second still grinds occasionally. I also have trouble shifting down to first while slowing down.
Old May 12, 2003 | 10:43 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
14,000miles for me..
zpeed350's Avatar
zpeed350
4400 miles here.
Old May 12, 2003 | 11:03 AM
vancitydude
10,000 km... about 6000 mi
Old May 12, 2003 | 01:07 PM
icepop456's Avatar
icepop456
I have 450 miles on mine and I noticed it right when I drove off the lot. I assumed (and still do) that it will loosen up with some driving.
Old May 12, 2003 | 03:03 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Unfortunately, it won't. I have 14k miles now, and it's not getting better. Even with Redline oil.
Old May 13, 2003 | 04:36 AM
zpeed350's Avatar
zpeed350
mine showed up right at 500 miles, and i thought the same thing. although lately it has been more "consistent". but i think that is more just because its starting to get warmer up here in CT.
Old May 13, 2003 | 07:24 AM
Selski12's Avatar
Selski12
Before change to Redline tranny oil:
shifting to 2nd gear was notchy and would sometimes grind only when its cold. Once the car warms up there is no problems
After change to Redline:
shifting to 2nd gear is less notchy and does not grind anymore. It has more of a solid feel to it than before. Overall it is a lot smoother after cold startups.
Currently 3700 miles
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
