clicking noise when turning left only
guys i hear a clicking noise when turning left, it sounds like it is coming from the right side of the car. It doesn't happen when i turn right or i go straight. It also depends how fast i'm going, a faster clicking or slower depending on the speed and how much i turn. Does anybody know what this is???? does it has to do with the axle?? thanks
i thought it was a ball joint.. but then after 2 weeks in the stealership i found out that it was lose bolt on the suspension.. before they charge you the whole nuckle arm that comes with balljoint.. make sure that all thebolts are tight
good luck
good luck
CV boots on your left axle. But for that, I doubt the noise is coming from the right; perhaps it just sounds that way. Just turn the wheel all the way to the left and examine your CV joint.
CFAUVEL
Oct 1, 2015 03:20 PM
