need help? gauge and cluster light dont work
Old Aug 14, 2007 | 07:53 PM
chi-Z's Avatar
chi-Z
Default need help? gauge and cluster light dont work
something went wrong im not sure if i blew a fuse or not but all the lights on my cluster and the three gauges is not working. i was working on my deck and when i put everything back together it didnt work check all the fuses but they were fine.check all the connections to ac box and the plug behind the three gauges in the center console. all the gauges work just the lights
dont come on.
Old Aug 14, 2007 | 09:29 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
dont come on.
Not working at all, or just extremely pale? There is adjuster if it's the later.
Old Aug 15, 2007 | 07:55 AM
VO...'s Avatar
VO...
Administrator
The white ribbon cable behind/below the center console and the single connector directly behind the cluster control the gauges. Have you check both of these?
Old Aug 15, 2007 | 07:26 PM
chi-Z's Avatar
chi-Z
i check the ribbon cable connections and the cable behind the three gauges already everything works its just the lights and the gauge that digital display all your speed tire pressure dont work. just wondering if any know the fuse or relay that might of burnt out
Old Aug 15, 2007 | 07:40 PM
cheshirecat79's Avatar
cheshirecat79
this may sound stupid but you did try the dimmer on the left side of the gauge cluster right
Old Aug 18, 2007 | 06:53 PM
kvp35's Avatar
kvp35
I did the same thing when I hardwired my old radar, my solution: Pop open the fuse box (next to clutch pedal) and I believe its a 10amp fuse marked "meter"- check/replace- solved my problem. GL.
Old Jan 15, 2008 | 03:06 PM
Hustler904's Avatar
Hustler904
mine just did the same thing,but also my cd player doesnt work. Installed my system about a month ago. I'll check that fuse tomorrow and hopefully thats the problem.
Old Jan 21, 2008 | 10:13 AM
3m wol8's Avatar
3m wol8
i blew my power mirror fuse and none of the gauges would work.. check that one.. it's by the driver's side kick panel
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
