BIG problem...need some help
Old Aug 27, 2007 | 06:17 PM
wckdclw's Avatar
wckdclw
Exclamation BIG problem...need some help
hey guys, im needin help pretty bad right now......i have a 03 z, and after installing my plenum spacer, i turn on the car, and a bunch of lights are on and it idles hard. it smells of as real bad and it will only accelerate up to about 800rpms. so i un-installed the spacer and now the only mods i have are the test pipes exhaust and jwt intake.....i kinda need to drive it to work tomm so i need to figure out what the problem is
Old Aug 27, 2007 | 06:20 PM
WhiteZon19s's Avatar
WhiteZon19s
Is it doing the same thing with it uninstalled?
wckdclw's Avatar
wckdclw
yeah
Old Aug 27, 2007 | 06:22 PM
wckdclw's Avatar
wckdclw
i have everything wired up for the nitrous also which is tapping into the throttle position sensor.....but my zex box isnt hooked up so that shouldnt be affecting it
Old Aug 27, 2007 | 06:24 PM
Rowlett's Avatar
Rowlett
Or you ma need to reset the ECU, if you want all the lights gone i did it works perfect a lil tricky but deff. plus+++
Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light. It's a little tricky, but works.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following two procedures quickly five times within 5 seconds:
1. Fully depress the accelerator pedal (HARD).
2. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the lights return then you have another problem some where....
practic the steps in your head then try them it will not hurt any thing if the lights are on now...what do ya have to loose!!!
Old Aug 27, 2007 | 06:25 PM
WhiteZon19s
What lights are on? Did you double and triple check that all lines are hooked up?Did you reset your ECU by taking off your negitive battery terminal for a little while?
Old Aug 27, 2007 | 06:26 PM
wckdclw's Avatar
wckdclw
im letting the ecu reset now, i guess overnight is the way to go.....and the pedal thing didnt work
Rowlett's Avatar
Rowlett
Installing the plenum, or even just removing the throttle body some small, will set the ECU off, its part of the Install to do these procedures just F.Y.I
As far as i know..
Old Aug 27, 2007 | 06:28 PM
Rowlett's Avatar
Rowlett
Improbly wrong, but disconecting the battery will trip the sensor, causing your car to idle very low
Please just try the ECU reset...it works
Old Aug 27, 2007 | 06:30 PM
wckdclw's Avatar
wckdclw
yeah, i installed the spacer about 2 months ago without a problem but lost the spacers to go underneath. i installed the spacer w.o them and still no problems...i finally got the spacers and installed them and now i had the problem....so then i just uninstalled the spacer and still the problems there
May 30, 2017 03:28 PM
Jambo016
Sep 16, 2016 01:08 PM
