OEM Window Motor FTL
Old Sep 17, 2007 | 11:25 AM
VO...'s Avatar
VO...
Administrator
Default OEM Window Motor FTL
My 2003 Touring hit the 31k mark recently and you got it, the passenger side window finally gave out. I spoke to a couple members and was informed the regulator and motor had to be replaced. I also searched abit and found some individuals were manipulating the regulator to kick in by banging on the inside of the door above the window switch while holding the switch up.
Happened to me yesterday at a local Hooter's car show. I had the window rolled down for spectators to look inside. When I packed up to leave, it never rolled back up. It just made a clicking sound. I knew the window was going out because it had been hesitating to roll up the past month. I'm gonna try banging on the door tonight. If it doesn't work I'll pick up some new hardware and make a DIY sticky out of it. I have some custom speaker/tweeter/dynomatt/wiring work done in the doors. I can't afford to have the dealership damage any of the mods.
Old Sep 18, 2007 | 06:49 AM
VO...'s Avatar
VO...
Administrator
Last night I put the key in and turn it all the way forward then pulled up on the window switch. I was about to bang on the side of the door but didn't have to. The window rolled up on it's own with no signs of stress or electrical fatigue. My guess is, the motor is good but the regulator is going out. Like others have said previously, the wiring harnest to the old style OEM regulators is substandard and the contacts become loose with time cause it to malfunction. Hence, the reason why it works when you bang on the door. I'm going to leave it as it is and worry about it when it stops working completely. When the time comes I might leave the motor in there but replace the regulator. Electrical motors/servos don't break one day then work the next. They usually have signs they are going out like burnt scents, slow to move, or whiny sounds. I'm almost positive it is the regulator, but not going to take the time to replace it until it totally ceases to function.
Old Sep 18, 2007 | 07:48 AM
JasonZ-YA's Avatar
JasonZ-YA
hopefully it doesnt stop on you and u end up in a picke like a rainy day or something....good luck
- j
Old Sep 18, 2007 | 07:58 AM
VO...'s Avatar
VO...
Administrator
- j
+1
VO(fingers crossed)
Old Sep 24, 2007 | 07:55 AM
VO...'s Avatar
VO...
Administrator
Default Update...
My window remained stuck in the down position twice this week. I used the bang on the door while depressing the window switch method both times, and it worked each time. The window rolls right back up. OEM regulator FTL. Maybe I'll get around to replacing it sometime in the future...
Old Sep 24, 2007 | 08:20 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Valentino those are the first signs of a bad motor and eventually it will stay stuck. I had to replace BOTH driver and passenger side motors on my Z however I am at 138k miles unlike your measly 31k miles. The motor itself is pricey from the stealership so you may have to find one used maybe in a salvage yard or something which is what I did............good luck bro
Old Sep 24, 2007 | 08:31 AM
VO...'s Avatar
VO...
Administrator
Thanks for the info bro. I hear they sell the motors at Autozone also. I'll look it up and post info when I find it..
Old Sep 24, 2007 | 08:55 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Really if they do please post that since my passenger one is once again acting up.
Old Sep 24, 2007 | 09:06 AM
NGZ's Avatar
NGZ
Have you checked out this thread?
https://my350z.com/forum/maintenance-and-repair/142013-window-motor-repair-replace-motor-brushes-2.html
Old Sep 24, 2007 | 09:38 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by NGZ
That was nice! https://my350z.com/forum/showpost.ph...6&postcount=23
Thanks for the link.
Old Sep 24, 2007 | 12:22 PM
Thanh386's Avatar
Thanh386
It's still under warrenty. TAKE IT TO NISSAN. Same thing was happening to my windows, turn out it wasa malfunction, they replaced the motor for free. But be careful. GWINNETT NISSAN are bastards, so thos in ATL with this issue take it someone else. They'll do whatever they can to take your money. They wanted 125 for a diagnostic test, saying that it could be an adjustment issue.
Old Sep 27, 2007 | 09:34 AM
mf01's Avatar
mf01
Are the Autozone motors remanufactured Nissan motors. I don't trust the motors that Nissan makes, since I've gone through 2 on my passenger door. If I have to replace it, out of pocket, I'd like to get something made by someone else.
Old Sep 27, 2007 | 09:37 AM
blasian's Avatar
blasian
Hey Val, have you tried cleaning it?
I cleaned the brushes on the passenger side about a year ago and mine is still working fine.
Old Sep 27, 2007 | 10:48 AM
mf01's Avatar
mf01
When my motor on my passenger door went out about 2 weeks ago, I cleaned out the inside of it. One of the magnets had a scar mark on it, so I think it'll crap out again. It's been working so far, but I'm waiting for the day I get stuck at work with the window down.
Old Sep 27, 2007 | 12:30 PM
VO...'s Avatar
VO...
Administrator
Naw, I guess if I'm gonna go thru the trouble of pulling it, I might as well replace it...
Old Sep 27, 2007 | 12:49 PM
blasian's Avatar
blasian
I suppose you could do that lol.
I was broke at the time and it looks like I lucked out
Old Sep 28, 2007 | 05:57 AM
mf01's Avatar
mf01
Here's the link if it hasn't already been posted
Driver:http://www.autozone.com/R,APP74403/v...ductDetail.htm
Passenger:http://www.autozone.com/R,APP74401/v...ductDetail.htm
Old Sep 28, 2007 | 09:05 AM
Jonathan Allyn's Avatar
Jonathan Allyn
Great thread!!! Thanks for kicking this link up. My drivers side window needs some serious attention now. I guess I can take care of that nasty streak now too...
Old Oct 29, 2007 | 02:50 AM
Sk8fe's Avatar
Sk8fe
Yesterday, my passenger side window goes down and then later decides its not going back up again! Arg! This thread has been very helpful to me in trying to understand my problem; however, what is the window regulator? Is it the actual door lock and window switch assembly or something entirely different?
I have an 03 Track with 25K on the clock. My driver's side window works. Both driver's side and passenger door lock buttons work; however, both driver's side and passenger side window buttons for the passenger window do nothing and I can hear a clicking sound coming from the passenger door???
Any advise would be greatly appreciated. Thx.
Old Oct 29, 2007 | 11:50 AM
mf01's Avatar
mf01
That's the exact same thing that happened to me. I started driving with the windows down, then turned on the AC, and hit the auto up. The drivers side came up, but nothing on the passenger. Both the passenger and driver's switches made the click. I took apart the window, cleaned all the debris out, then it worked again. It's been about 3 months now, but I think it will eventually fail.
You could clean it out or replace the motor from autozone.
