Does anyone know the Nissan part# for the copper crush washer used for the oil pan drain plug? I found them on Courtesy Nissan parts (http://www.courtesyparts.com/Merchan...e=11026-VQ35DE); however I do not think the number they list is the Nissan part# since nothing comes up when searching on EverythingNissan.com. Thanks.
Has anyone replaced their oem drain plug with a magnetic one? I want to do that...
If it were a space age "aluminum" magnet it would be helpful. Your crank is steel----But no wear there. Your rings are magnetic----if one breaks, your drain Magnet wont help. Your pump gears are steel-----IF one chips, it will be trapped in the filter. Everything else is Aluminum.
