Wind noise after replacing window
Old Oct 12, 2007 | 06:21 PM
Troy9's Avatar
Troy9
Default Wind noise after replacing window
My car got broken in to and the drivers side window was replaced. Now there is major wind noise, how can i get rid of that?
thanks
Old Oct 13, 2007 | 01:49 PM
Al_s14's Avatar
Al_s14
i am assuming it wasn't the Nissan/Infiniti that performed the repair? most likely cause is not adjusted door glass. just look fro the gap at the top with door closed . there should not be any and should be even across. If it is crooked
you will need to remove the door panel and adjust the glass. it is probably sitting crooked. To do that:
Remove door panel
Remove 3 rubber circular covers that cover 3 holes through which you can get to the 10mm bolts that secure the glass. sit in the car and close the door.
Connect window switch
put window all the way up. brake loose all 3 bolts. You should see the glass level out. Usually that is sufficient if not with bolts loose (door still closed with you sitting in the car) put window down then all back up. Tighten the 10s. get out of the car and check gap at the top of the glass.
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
