Sputtering During Warm-up
Old Nov 11, 2008 | 10:54 PM
  #301
GHOST1207's Avatar
GHOST1207
Originally Posted by JZK
Hmm, my car idles roughly at about 900 rpms, what about everyone else's rpm? Im trying to see if this is normal or not. This is without a/c
900-1200 from a cold start with high oil pressure.
400-500 from a warm start and after oil pressure is down.
Both with a/c off.
900 is pretty high. Could it be because of your tune?
Old Nov 19, 2008 | 02:30 PM
  #302
stylett9's Avatar
stylett9
Not sure how much this will do or accomplish, but next time the "sputtering" occurs, could everyone SLOWLY rev between 1000-2000 and see if your engines "hickup" at 1700 RPM's. Even after the sputtering stops, i've noticed that if you rev your engine really slow not in gear, it will still produce a SMALL hickup at 1700. So the problem never really goes away, just get's drastically more mild.
Old Nov 19, 2008 | 03:26 PM
  #303
Mansmind's Avatar
Mansmind
I've already done this, and you're exactly right. If you pay very close attention you can feel it even moving at highway speeds. Now...having said that, I truly believe this issue to be throttle position dependant, not rpm dependant.
I've felt the hiccup at different engine speeds, but always at what I call very light throttle. I would guess at something under 5% throttle.
Old Nov 19, 2008 | 05:37 PM
  #304
Tac-M's Avatar
Tac-M
now with the first cold day... it got worse ! it takes longer to warm up so misfire is getting very annoying !
i am pissed right now... what tha hell ! there are a ton of vq35hrs out there ! why are they all sitting quiet about this?!?
Old Nov 27, 2008 | 10:22 AM
  #305
Tac-M's Avatar
Tac-M
^ a week after ..... my problem is gone.
here are the 2 things i changed.
1 - cobb ap stage 2
2 - changed oil from motul 10w40 to mobil1 5w30 ( i did 2 changes in 1 day to do a better flush )
engine is smooth as silk at all rpms.
i will update in a few days to confirm.
Old Nov 29, 2008 | 08:01 AM
  #306
stylett9's Avatar
stylett9
1 - cobb ap stage 2
I've swapped motor oil many times so i'm willing to bet it's all on your engine flash. Keep us posted.
Old Nov 29, 2008 | 06:46 PM
  #307
Tac-M's Avatar
Tac-M
i think you are right.... if you are tired of this "bug" 695 is a small price to pay to have it killed.
cobb ap FTW !
Old Dec 6, 2008 | 12:06 AM
  #308
stylett9's Avatar
stylett9
for any of you that are unsure if you have this issue or not. This is a video of what your engine will do AFTER the main sputtering occurs. Notice how the engine bogs at 1700 RPM. The car will do this for awhile until completely warmed up.
http://www.youtube.com/watch?v=rYVHjeAa5EM
Old Dec 11, 2008 | 05:49 PM
  #309
Tac-M's Avatar
Tac-M
update - absolutely no more sputtering . cobb ap fixed it for me. technosquare would do the same.
bottom line - it is software ( map ) related.
Old Dec 12, 2008 | 10:15 AM
  #310
stylett9's Avatar
stylett9
what was the turn around time on your reflash? Did you have to take the ECU out and mail it?
Old Dec 12, 2008 | 11:47 AM
  #311
Tac-M's Avatar
Tac-M
no no ! cobb access port is a handheld device that you buy ! it's yours to keep ! cobbtuning.com
check it out !
Old Dec 19, 2008 | 05:23 PM
  #312
gennosuke1's Avatar
gennosuke1
**** man i remember reading this thread a coupl days ago and was like wtf is up with their car.
right now i got in my car and what do you know bam it happens, so i come into this thread....
i have an 06 with nismo and test pipes. i put one sparkplug there and need to get another so im not sure if it is the sensors that is causing this or if its the water.
over the past week here in oc has been raining so maybe some water has got into my tank? Now i dont know which it might be water in gas tank or sensors for the test pipes...
edit it doesnt seem to go up and down like that video but it seems to be idle at 2,000 rpm
Old Dec 20, 2008 | 01:28 AM
  #313
Tac-M's Avatar
Tac-M
i don't think you have the same problem. as far as i know this only happens to HR and VVELHR
Old Dec 20, 2008 | 01:33 AM
  #314
Tac-M's Avatar
Tac-M
little update for the rest of us.
i was absolutely sure that the flash fixed my problem.... until i drained mobil 1 and put back motul 10w40. as soon as i did that problem came back. i then drained 10w40 ( $$$ ) and replaced it with also motul but 5w30 - and guess what ? no more sputtering....
so would someone explain this to me ?
also, if you look on g37 forums, you will find that nissan made and patented an ester based oil that they recommend to use in vvel engines to fix the problem that we are having. WTF !~
http://forums.g37driver.com/zerothread/369083
Old Dec 20, 2008 | 05:19 AM
  #315
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
I am using Motul 300v Chromo (change it every 500 to 750 miles) .. and have the AAM reflash and still experience the sputtering.
Old Dec 20, 2008 | 09:32 AM
  #316
Tac-M's Avatar
Tac-M
that is right, chrono is 10w40, 5w30 is called power racing. try that one next time. and see what happens
Old Dec 20, 2008 | 10:10 AM
  #317
Ex2cinaZ's Avatar
Ex2cinaZ
Destructo Girl
I have a few cans of the chromo left.. after that's done I'll switch.. thanks for the advice... hope that works
Old Dec 20, 2008 | 12:01 PM
  #318
gennosuke1's Avatar
gennosuke1
how come my rpm goes to 2,000 then?
this was a first last night
actually 1600 or 1700
Old Dec 20, 2008 | 04:25 PM
  #319
Tac-M's Avatar
Tac-M
^ how long does it last? and when exactly does it happen? does it go above 2000 ? any CEL?
Old Dec 21, 2008 | 12:47 PM
  #320
gennosuke1's Avatar
gennosuke1
^^ Yes the check engine light or service engine light does come on. It last until the car has warmed up. Does not go above 2,000. It sits around 1700-2000
Could this be the cuz of not getting the foulers. I have one on each side but i need 2 one each side so i am getting that tomorrow
