Sputtering During Warm-up
Old Nov 5, 2010 | 06:57 AM
  #521
srsairbags's Avatar
srsairbags
gj fastgreg . . . im gonna need a coffee to go through this info . . . my head isnt working right today
Old Nov 5, 2010 | 07:15 AM
  #522
FastGreg's Avatar
FastGreg
Don't know if our problem come from this recall, but I will try to call Nissan for an update of the ECU...
Anyway I don't know if the ECU must be change or if Nissan can re-write the software on the current ECU ?
Old Nov 5, 2010 | 12:52 PM
  #523
srsairbags's Avatar
srsairbags
was bored . . called up nissan consumer affairs . . . it seems the ECM is part of an emission control warranty and is covered till 4 years/80k miles whichever is earlier . . .
but im still curious . .as to why the techno-square re flash didn't fix this . . . even osiris for that matter
Old Nov 5, 2010 | 12:59 PM
  #524
Q8y_drifter's Avatar
Q8y_drifter
Probably because they don't touch the maps responsible for cold starts.
Old Nov 5, 2010 | 08:56 PM
  #525
FastGreg's Avatar
FastGreg
I already tooke an appointment, next Friday, the 12th, for an update of the ECU to the Nissan garage... But I really not confident... Do the Nissan garages received the new software ???
In the mean time, I will try to change my O2 sensors tomorow.
Old Nov 5, 2010 | 10:02 PM
  #526
srsairbags's Avatar
srsairbags
good luck . . . hopefully the afr sensors will fix the issue
Old Nov 6, 2010 | 05:15 AM
  #527
FastGreg's Avatar
FastGreg
Old Nov 6, 2010 | 05:32 AM
  #528
FastGreg's Avatar
FastGreg
Follow up:
http://blogs.yahoo.co.jp/neko_technology/2248049.html
Presently it is corresponding with [ripuroguramingu], so is. When (gratuitousness) it is not repaired even with [ripuroguramingu], unit exchange it probably will put out, is. (Charge? Gratuitousness? ) Looking at this [burogu] even with your our company customer, [ripuroguramu] the customer who does was with itself, but hunting was not repaired. HELP call came to our company then. Promptly, you sent unit, initialized memory, returned. As for the vehicle of the customer, hunting stopped exactly, so is. It was good, it was good!!! Note: When this initialization is done, study and the like of the electromotive throttle by the diagnostic machine becomes necessary. Usual [ripuroguramingu] only modifies the modification data of the program which is written in the micro-computer. At present, because it seems that is not the entry equipment and material which had memory initialization function the kana ~ which probably will be made! When such a function it is, the kana ~ which rejoices?
Old Nov 6, 2010 | 07:11 AM
  #529
BlaQ350z's Avatar
BlaQ350z
^ I am lost
Can anyone translate?
Old Nov 6, 2010 | 04:28 PM
  #530
srsairbags's Avatar
srsairbags
You never know 
Old Nov 7, 2010 | 06:19 AM
  #531
FastGreg's Avatar
FastGreg
You never know 
So, both front O2 sensors changed, now waiting for a cold start tomorrow morning
Old Nov 7, 2010 | 11:04 AM
  #532
srsairbags's Avatar
srsairbags
shouldnt you do an ECM reset also ?
Old Nov 7, 2010 | 11:53 PM
  #533
FastGreg's Avatar
FastGreg
I don't know if it's useful for such change, but I can try it !
Old Nov 8, 2010 | 04:37 AM
  #534
FastGreg's Avatar
FastGreg
Originally Posted by Q8y_drifter
Were there any recalls / tsb's in the US regarding the ECU's?
It seems no : http://www.nissan-techinfo.com/TSB/T...CONTROL+SYSTEM
Old Nov 8, 2010 | 06:03 AM
  #535
srsairbags's Avatar
srsairbags
update
Old Nov 8, 2010 | 10:21 PM
  #536
FastGreg's Avatar
FastGreg
No times to test the car yet, sorry... More news at the end of the week, I hope !
http://www.vimeo.com/16669765
A video from a belgian 2008 Z, no comment....
I also open a thread on the french 350Z forum, if it can help...
http://www.notre350z.com/forum/viewp...58.html#381058
Old Nov 10, 2010 | 10:49 PM
  #537
FastGreg's Avatar
FastGreg
update
Still sputtering with brand new front O2 sensors...
- Spark plugs: NO
- Ignition coil: NO
- O2 sensors: NO
- Engine coolant temperature: (I check it with the OBD data logger, and seems to be fine)
- Vaccum leaks: ( temperature/time specific leaks is unheard of . . soo ill say NO)
- Crankshaft sensor:
- Exhaust valve timing position sensor:
- IVT:
- MAF sensor: at least cleaning old ones - NO
- IAT sensor:
- TP sensor:
- Cleaning TB: done, whitout change - NO.
- ECU/EM:
Old Nov 11, 2010 | 05:48 AM
  #538
srsairbags's Avatar
srsairbags
- Spark plugs: NO
- Ignition coil: NO
- O2 sensors: NO
- IVT:
- IAT sensor:
- TP sensor:
- ECU/EM:
ok . . soo that pretty much settels it . . . it has to be the ECM . . .
sooo 2 ways to goo . . . get nissan to replace/reprogram ECM . . or get an aftermarket ECM . . .( not the piggyback ones - stand alone . . like HALTECH)
. . im gonna try and see if i can have a local nissan dealer do the former for meee
Old Nov 11, 2010 | 06:08 AM
  #539
FastGreg's Avatar
FastGreg
Will go to Nissan dealer tomorrow to know if update software for our ECM is available... And if they can erase ECM memory with the Consult III.
And reprograming ECM accordingly. Will keep you posted guys.
Old Nov 11, 2010 | 07:11 AM
  #540
archangel72's Avatar
archangel72
^Thanks. I haven't posted on this thread yet, but have been having the same problem. It wasn't always like that I bought my 07 base used last September, and this strated happening maybe 6 months or so. Oddly enough, it rarely happens to me in the morning, it almost always does it when I leave work in the afternoon, when the car has been sitting in the sun all day. Once I start the car if I put it in gear and leave right away theres less of a chance of it sputtering. The lower the gear the more violent the sputter, but like you guys said, if i just let what ever gear i'm in wind-out it will go away
