30k service really worth it???
on
The last time i was at Nissan they asked if I wanted to schedule my 30k service. Last time i checked the 30k service did not include much, actually they CHECKED mostly everything (fluids, brakes, etc..) and actually don't fix much if any..pls correct me if i am wrong.
I was hesitant to say yes then the service guy said.."I notice that you have the extended 100k mi warranty, u know the first thing we look at when warranty issues turn up is to see if you have kept up with your services."..although this may sound logical, the idea of paying a couple hundred dollars for them to LOOK at my fluids is rediculous. He continued and said that i didn't even have to get it done at nissan, as long as i have documentation showing that i had it done somewhere.I even remember reading a thread here saying that dealerships actually laugh at ppl who pay for the 30k. Worth it or not??
on
never worth it. If you look at the list of what they do and the price you are going to pay, it's rediculous. You can pay me 1/4th of that price and i'll do it for you.
on
on
I know most dealerships dont' do all of this so you will have to get a copy of what they will do from the dealership you are goign to.
This is from nissan's website for the 30k check up, exclude the ones where it says 4wd/awd
Replace engine oil and filter
Lubricate all locks/hinges
Lubricate propeller shaft (4WD) 1
Road test vehicle
Replace automatic transmission/CVT fluid
Replace differential oil (limited-slip, conventional) 2
Replace engine air filter
Replace engine coolant/flush system
Replace engine drive belts
Replace free-running hub grease 3
Replace front wheel bearing grease (4WD only) 4
Replace fuel filter 4
Replace in-cabin microfilter 5
Replace limited-slip differential oil
Replace manual transmission oil
Replace PCV filter (4 cylinder Frontier/Xterra)
Replace radiator cap
Replace radiator hoses
Replace spark plugs
Replace timing belt
Replace transfer case oil (4WD/AWD)
Replace water pump
Replace wiper blades
Rotate tires (except 350Z)
Optional: flush automatic transmission (flush with ATF)
inspection:
Air conditioning system
All lights
Automatic transmission/CVT fluid
Axle & suspension parts
Battery fluid level/terminals
Brake lines & cables
Brake fluid level
Brake pads, rotors, drums & linings
Charging/Starting system
Clutch fluid
Cruise control vacuum hoses
CVT fluid (Murano)
Differential oil 2,8
Drive shaft boots 6
Engine air filter
Engine coolant level/top-off
Engine drive belts 9
Exhaust system
Free-running hub grease
Front suspension ball joints
Front wheel bearing grease (2WD only)
Fuel lines/connections
Fuel tank vapor vent system hoses
Headlights/adjust if necessary
Horn operation
Limited-slip differential oil
Manual transmission oil 8
Power steering fluid/top-off
Propeller shaft 2
Radiator hoses
Shock absorbers/struts
Steering gear and linkage
Steering linkage ball joints
Tires/adjust air pressure
Transmission fluid/oil
Transfer case oil (4WD/AWD) 8
Washer fluid level/top-off
Wiper blades
Road test vehicle
Replace spark plugs
Replace timing belt
Replace water pump
inspection:
All lights
Brake fluid level
Clutch fluid
CVT fluid (Murano)
Drive shaft boots 6
Engine air filter
Exhaust system
Horn operation
Propeller shaft 2
Radiator hoses
Wiper blades
![](https://my350z.com/forum/images/ranks/premier.gif)
![](https://my350z.com/forum/images/ranks/moderator.gif)
LOL , they probably dont even do 1/4 of what they say.
on
i tried searching for the price at the local dealership here but i couldn't find one. How much did you guys pay for the service if you had it done at Nissan? What's the general price?
on
on
most of the stuff SuperBlack350z posted is incorrect. it must be for some different service. that list includes replacement of belts water pump timing belt and fuel filter(in tank not serviceable) , spark plugs.none of that stuff is applicable. that sounds more like a 100k on a QX4
only thing you actually need to do at 30 is Coolant and balance tires.obviosly rotation is not applicable. essentially thats all dealer does besides oil change. cabin filters too but i cant remember if z's have it. then rest of the stuff is just a big check list.
PS i assumed your car is a 6spd but if its auto get a trans flush done.
08-06-2021 06:19 AM
