Is this common??... Grinding sound during Startup
Old Oct 27, 2007 | 06:14 AM
skn5002's Avatar
skn5002
Default Is this common??... Grinding sound during Startup
My car runs fine. But... when I start it up in the mornings, it makes this weird sound when I engage into gear. The sound occurs only when I am feathering the clutch up to engage into 1st gear or reverse or just putting it back into neutral. It makes a loud grinding sound...as if the flywheel is rubbing against something. This only happens when the car is cold. When the car is warmed up, the sound is non-existant. A friend told me this was common with all the Zs on a cold start up. Is this true?
Old Oct 27, 2007 | 09:40 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Its never happened on mine in almost 5 years.
Is it coming from engine or tranny?
Old Oct 27, 2007 | 09:58 AM
skn5002's Avatar
skn5002
It comes from the tranny, perhaps from the flywheel. Sounds like a whirling/rubbing sound. Only occurs when the motor is cold.
Old Oct 27, 2007 | 01:44 PM
merlin3's Avatar
merlin3
is it it maybe grinding into gear because the clutch isn't releasing all the way? maybe bleed the clutch or adjust it.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
