Dash lights are on!
Old Nov 24, 2007 | 10:28 AM
acmw's Avatar
acmw
Default Dash lights are on!
My airbag light is flashing, the brake light stays on and so does the vdc and slip light. What can i do to get rid of these lights?
Old Nov 24, 2007 | 11:02 AM
SteevoZ's Avatar
SteevoZ
Reset the ecu by using the key turning and gas pedal sequence. I think its on the forum somewhere. If I come across it I'll post it here.
Old Nov 24, 2007 | 11:14 AM
350ZTheStandard's Avatar
350ZTheStandard
Trip to Nissan stealership, mine charges $80.00 to reset the computer on the seatbelt light.
Either way dealer always tries to tell me it has to do with me changing out a stereo, this is BS cause I changed out the stereo approx 2.75 years ago. Stealership always trying to cover their own a$$, but in the end they just reset the computer, yes free of charge.
Old Nov 24, 2007 | 11:19 AM
SteevoZ's Avatar
SteevoZ
Here i found the website with the procedure.
http://www.technosquareinc.com/350reset.htm
It says to use a stopwatch but I did it once without, I just counted in my head. I might have gotten lucky with the timing though.
Old Nov 24, 2007 | 11:57 AM
DavesZ#3's Avatar
DavesZ#3
If you can't get the reset procedure to work that way, you can "brute force" it by disconnecting the battery then pressing the brake pedal for a few seconds. Failing that, leave the battery disconnected overnight.
Old Nov 24, 2007 | 01:43 PM
undrgnd's Avatar
undrgnd
Better yet, a code scanner works wonders. So does Uprev's Cipher.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
