Chewed up wire
Old Dec 2, 2007 | 03:53 PM
350zlmtd's Avatar
350zlmtd
Question Chewed up wire
So I go to put my car away for storage lift up the hood to disconnect the battery and a wire that is bolted to the engine is chewed up really really probably by some animal. What is this wire to and how much will it cost estimate to replace? Please any help thanks
edit: sorry for the crappy first pic I used my cellphone that was the only thing I had at the time
Old Dec 2, 2007 | 05:14 PM
Corradoslc7's Avatar
Corradoslc7
I can't really make it out but it is probably a ground wire. Make sure you fix it before running the car.
Old Dec 3, 2007 | 05:39 AM
Eazzy's Avatar
Eazzy
Those pics just plain suk----If its black and a single 10-12 Ga then its a ground. If it is in a shielded cluster, I have to see a clear close up. If its a Ground, no big deal and repair it mainly for cosmetics.
Take your cover off and do a complete inspection of other possible wire probs----Mice dont just chew on Ground wires.
Do something about the rodents----Bait poison, moth ***** etc
Old Dec 3, 2007 | 07:05 AM
My server is blocking your photos.
Reason: The Websense category "Sex" is filtered.
Old Dec 3, 2007 | 12:36 PM
350zlmtd's Avatar
350zlmtd
Yea sorry I know those pics suck a$$ all i had at the moment. Hopefully this will help a little better. The wire that is mounted to the engine circled in yellow is the chewed up wire. I have had problem before with chewed up sensor wires so I believe there is some kind rodent. If anybody could please explain to me what this wire is to and how much it will cost to repair or maybe a easy fix idea. Thanks
Old Dec 3, 2007 | 12:41 PM
Eazzy's Avatar
Eazzy
Well ---you really didnt answer my questions but if it is about 3/16 Dia. O.D. and is Black it is a Ground and just a simple basic repair is sufficient
Old Dec 3, 2007 | 01:19 PM
350zlmtd's Avatar
350zlmtd
I believe so I really dont know the gauge on it just a little bigger then your normal speaker wire. Is it a simple as a splicing it and adding new wire? But I would like to have a definite answer as to what that wire is?
Old Dec 3, 2007 | 01:32 PM
Eazzy's Avatar
Eazzy
3/16 is 3/16 ---for the third time with all due respect ---IS it Black ???
Old Dec 3, 2007 | 01:45 PM
Eazzy's Avatar
Eazzy
Either way ----Just repair it. Solder it if you like and use shrink tubing. Disconnect the Battery just to cover your butt.
Old Dec 3, 2007 | 05:03 PM
JonsilvZ's Avatar
JonsilvZ
Next time leave the battery connected. So the sucker gets it!
Old Dec 3, 2007 | 05:28 PM
350zlmtd's Avatar
350zlmtd
Yes it is black same color as pictured.
Old Dec 3, 2007 | 05:34 PM
Eazzy's Avatar
Eazzy
If I offer advice from a 1000 miles away and it pertains to someones car, I like to be sure ---If it is Black and is not covered with a wrap, as the clusters next to it, then it is a ground and if the wire strands are intact, can be repaired by wrapping at the least and cutting, soldering and shrink tubed at the most. No big deal and does not pose a hazard
Old Dec 3, 2007 | 06:14 PM
350zlmtd's Avatar
350zlmtd
Yea it is not covered with a a wrap. I will probably have to cut out a section since it is chewed up pretty badly. The ground wire 3/16 or was that just a estimate? I really have no idea on wire gauge sizes.
Old Dec 3, 2007 | 07:04 PM
Eazzy's Avatar
Eazzy
I used 3/16ths of an inch to simpify things for you. It's a 12 Ga. I would guess. Its a ground, you can cut it and add another end and ground it elsewhere on the motor if you want. Grounds are important, but its just a Ground. There is no Positive Current
Old Dec 3, 2007 | 08:29 PM
350zlmtd's Avatar
350zlmtd
OK thanks for the feedback and help
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
